how to check if CEL is working
Old Aug 4, 2002 | 07:39 PM
NegativeLift's Avatar
Default how to check if CEL is working
How do you check if your check engine light is working?
Old Aug 4, 2002 | 07:55 PM
areyouasian's Avatar
Default Re: how to check if CEL is working (NegativeLift)
there are various things that will trip a CEL...for instance...if you dont screw down gas cap tight enough the CEL will come on...or just unplug an O2 sensor that will trip a CEL too...just set up one of those situations and you will see if it turns on...if it does, then it works...then reset the ecu to turn off the CEL....
Old Aug 4, 2002 | 08:02 PM
Brian_92GSR's Avatar
New User
It'll come on for a second or two when you first turn the car on.
nus_dogg
Jul 24, 2009 02:30 PM
Flava
Aug 4, 2006 12:58 PM
CRXified
Jul 30, 2005 01:31 PM
See Are X
Jul 13, 2003 09:26 PM
