help plz, Radius rod bolt stuck!
Old Dec 28, 2008 | 06:30 PM
ludekid4323's Avatar
Default help plz, Radius rod bolt stuck!
Ok, sooo my 4th gen has always wobbled like crazy while accelerating so I replaced spring isolators, tie rod ends, upper ball joints, upper control arms, sway bar bushings, sway bar endlinks, and anything else that was torn/dry rotted. Nothing fixed my vibration problem so i ordered 2 new axles from autozone. The drivers side came out fine but now the passanger side is messing with me. Where the radius rod end bolts into the lower control arm, I am unable to remove one of the two 17mm bolts. I've used breaker bars, liquid wrench, openends and a bunch of other crap and all its doing is getting rounded off. The bolt is right under the axle so I am unable to get an impact or any other air powered tool in there. My last resort at this point is taking a tourch to the bolt to heat it or drilling it out. Any advise guys??? Thanks
Old Dec 28, 2008 | 07:09 PM
Giant_Bean's Avatar
Default Re: help plz, Radius rod bolt stuck!
there is no reason to remove the radius rod, you just have to pop off the lower ball joint, and the fork on the bottom of the shock.
Old Dec 28, 2008 | 07:19 PM
The only reason why I want to drop the lca is because I just installed a new lower ball joint and I dont want to tear the boot by prying up on the ball joint and the knuckle...
Is there a way to lift the knuckle/ball joint out of the hole in the lca without damaging the new ball joint?
Old Dec 28, 2008 | 08:07 PM
RomPirate's Avatar
Yeeep... thats a complete PITA to get off.... How did it get rounded? I dont see it happening unless you used a 12pt....
Mine came off pretty easy. I had to buy a ~9" 17mm wrench just for it, but it worked.
Old Dec 28, 2008 | 08:17 PM
The previous owner messed up so many things...including rounding off a bunch of bolt heads. Sometimes I just wish that my car was stock :/
Old Dec 29, 2008 | 04:20 AM
Giant_Bean's Avatar
try one of these:
Old Dec 29, 2008 | 07:03 AM
I heated it up this mourning and it unscrewed. Thanks for the help
Old Dec 29, 2008 | 06:33 PM
Crash_Control's Avatar
This is my favorite tool to use for the lower ball joints and outer tie rod ends.
Just remember to leave the nut on enough to protect the cotter pin holes.
drbenne
Dec 7, 2014 09:01 AM
LOC714
Nov 14, 2009 11:30 PM
EFin' Kyle
Mar 31, 2009 05:08 PM
eg6civic1538
Mar 20, 2008 04:45 PM
crxnj
Dec 11, 2005 10:28 AM
