d16z6 distributor question,,,,help.
what exactly is the difference between a 93 civic dx dist and a 94 d16z6 dist? does the p28 have to have the vtec dist? got my 90 civic running tonite obd1 but check engine lite is on. also, how do you check codes on obd0-obd1 conversions? so many questions, so little time.
the only difference between the two is the placement of the mounting hole besides that is should work what ECU are you using OBD1 or 0 that will help me help ya
when i turn on the key to the run position, without starting the motor, the engine cel comes on with the fuel pump, then goes off fo r a second, then comes back on and stays on. same way it does with it running. tried jumping the connector, didn't do anything. traced the wires and they are all hooked up correctly between the jumper and the computer. I guess I'm gonna have to go thru wire by wire and check everything again. any ideas? oh, I also tried pluggin in the 93 dx computer but cel did the same exact thing.
[Modified by civicwagonman, 1:09 PM 8/5/2002]
miasma
Feb 5, 2007 04:24 AM
civicwagonman
10
Aug 8, 2002 07:29 PM
