Red Coolant/Antifreeze in a Honda
Old Aug 4, 2002 | 07:12 PM
rus's Avatar
rus
Default Red Coolant/Antifreeze in a Honda
Picked up some Prestone coolant today, didn't realize that it was RED until I got home. It's phosphate/silicate free, just like Honda stuff. Seems like many new cars come with it.
Should I get some Honda antifreeze instead, or is this stuff good?
Old Aug 4, 2002 | 07:28 PM
obd2gsr's Avatar
Default Re: Red Coolant/Antifreeze in a Honda (rus)
should be fine.
Old Aug 4, 2002 | 07:42 PM
M0NEYnH0s's Avatar
I had the same delema u did when i was changing my thermo, but it was too late for me to go exchange it. Ive been running it for about ~10k and no problems at all. Although I have heard that switching from the green to red kind can cause corrison in the water pump. anyone else?
Old Aug 4, 2002 | 07:51 PM
rus's Avatar
rus
Default Re: Red Coolant/Antifreeze in a Honda (m0neynh0s)
55K on the clock, ECT (Engine Coolant Temperature) Sensor went bad. Temporarily fixed it with a paperclip, but figured I should replace it one of these days. Replacing thermostat as well.
Ran 85% water/15% green coolant for the past 3 months, figured might as well go back to 50/50 once I replace ECT/thermostat.
If the corrosion myth is indeed true, I'd rather hold off and get proper antifreeze. What's everyone running anyway?
Old Aug 4, 2002 | 09:33 PM
SloEG's Avatar
Water Wetter + distilled water over here....no coolant
Old Aug 5, 2002 | 02:49 AM
EE_Chris's Avatar
Your saying you used a paperclip to short together the terminals in the ECT connector? Might try a 330ohm resistor, which more simulates a fully warmed up car.
Old Aug 5, 2002 | 04:34 AM
quis23's Avatar
https://honda-tech.com/zerothread?id=194103
99bb6
10
Sep 23, 2004 08:36 PM
importdude2000
Jun 4, 2004 02:08 PM
david90
Aug 31, 2003 09:00 AM
KOALA YUMMIES
Dec 3, 2002 01:50 PM
