need help with a f22a1
Old Dec 28, 2008 | 01:13 PM
AccordNation's Avatar
Icon3 need help with a f22a1
ok i took a f22a1 bottom end and took a f22b1 head on put it on and used the b1 head gasket i started it up it ran fine but when i was puttin water in,it started to come out in the front behind the header i put my finger down there and i felt a little hole thats in the head gasket and thats were the water was comming from?
Old Dec 29, 2008 | 05:55 AM
Default Re: need help with a f22a1
morning bump
Old Dec 29, 2008 | 08:43 AM
thadelsolryda's Avatar
the only thing i can say is to pull the head back off and check it because somtimes when u do that u gotta block ports. did everything on the head gasket line up with the block
Old Dec 29, 2008 | 10:48 AM
yea,but i used the b1 head gasket its like a port on the front if the head thats were the water is comming out
Old Dec 29, 2008 | 02:45 PM
come on i know someone knows something bout this
Old Dec 29, 2008 | 03:42 PM
is ti a threaded hole
Old Dec 29, 2008 | 05:47 PM
hon2984's Avatar
That is a coolant jacket and needs to be plugged. Remove the cylinder head. Use a Tap and cut some threads in the cylinder head and install a plug. U could chance it a use JB weld, but its not a good idea. You also need to remove the oil restrictor that sits above the oil pressure sending unit passage. It is built into the cylinder head somewhere. If it is still there you will not have sufficient oil flow to the head.
Old Dec 30, 2008 | 01:45 PM
i took the oil plug out but,what would be the best way to plug it cuase it was water that came out.cause if thats the case i will go ahead and the head off tonight,thanks hon2984
Old Dec 31, 2008 | 07:29 AM
morning bump
Old Dec 31, 2008 | 03:17 PM
nightly bump
Old Jan 2, 2009 | 09:49 AM
bump
Old Jan 3, 2009 | 02:34 PM
hon2984's Avatar
Look in the FAQ forum on the F22b1 head swap, you will see how he talkes about the block being redesigned in 94 by addling a ledge where that coolant jacket is. He used JB weld! But I would still plug it, u dont want to overheat on the highway because your fake weld blew out!
Old Jan 5, 2009 | 09:04 AM
that is true i really dont want to overheat
Old May 4, 2011 | 10:33 PM
zach53's Avatar
tap some threads and thread a plug in
Old May 4, 2011 | 10:36 PM
zach53's Avatar
YEA JB WELD IS A HIGHWAY FIX NOT A permanent!! pul the head off and plug it DO IT RIGHT the first time or regret it later bro
strike1545
May 24, 2010 10:42 AM
Br1t1shguy
Dec 16, 2006 07:27 PM
dpkelly
Apr 20, 2006 11:54 AM
K-Drum
Dec 8, 2004 12:26 PM
ITR_1211
Jan 5, 2004 09:04 PM
