electric problem on 1992 civic dx hatch help!!
Old Dec 28, 2008 | 11:06 AM
greyeghatch's Avatar
Default electric problem on 1992 civic dx hatch help!!
hey guys i got a 92 civic dx hatch and it ran great till like a week ago when i got my si i left the hatch parked and when i went to go start it nada happen.now i have put a new starter and battery in it and still nothing at all not even the headlights the only thing that works is the hazard lights.ok now today when i went out side to work on it guess what a rat was in the trunk so now im thinkin he went under the dash and ate the harness is this possible?or could it be my main relay?
Old Dec 28, 2008 | 03:06 PM
doc's Avatar
doc
Default Re: electric problem on 1992 civic dx hatch help!!
Check the fuses in the engine bay fuse box.
The hazard flasher is more or less direct connected to the battery. Everything else goes a different electrical path trough some fues in the engine bay fuse box.
Check the 80A (No. 41) and 50A (No. 39) Fuse first.
Old Jan 1, 2009 | 09:01 PM
will check bump
Old Jan 3, 2009 | 04:03 PM
tech7427's Avatar
doubt its main realy, ur hazard lights work because it is a direct connection to batery voltage without a relay or switch to supply power to the hazrd button. seems like a wiring problem probably that rat, also could be an ignition switch power if you turn key on and nothing happens. what exactly happens when you turn the key to the on pos?
Old Jan 4, 2009 | 07:43 AM
fcm's Avatar
fcm
Old Fart
I have to agree with the above^^^
It is unlikely to be the PGM-FI Main Relay, [main relay] it has no control over things like head lights, cranking to start, it controls power to the fuel pump, fuel injectors, a few engine sensors and one of the switched powers to the ECU/ECM.
So pretty much the same question as above, what works?
You say the only thing that works is the hazard lights, nothing else, no dome light, trunk/hatch light, cigarette lighter, horn, notheing?
If so I am going with the rat and a wiring issue.
Do you have or can you borrow a multimeter or a good test light? 94
Old Jan 7, 2009 | 08:28 AM
when i turn the key to the on posistion nothing happens it dead silence only thing that works is hazards.i took the dash out and gutted the whole car all the wires are untouched im completly confused headlights dont even turn on neither does the dome light this sucks
Taylor1976
May 13, 2018 04:05 PM
Cody Wilson
Apr 7, 2016 04:38 PM
93slmdcvcsi
18
Jul 17, 2010 08:30 PM
Lone_Bassist
May 9, 2009 05:54 AM
transitions
Apr 15, 2007 05:38 PM
