prelude reverse lights not coming on!!
Old Dec 28, 2008 | 10:31 AM
H22LUDE808's Avatar
Default prelude reverse lights not coming on!!
i finally finished my JDM H22 swap into my 92 prelude si. i also converted my prelude from automatic to 5 speed. the plug that went into the auto shift assembly has nowhere to be plugged into.
can i wire it to a switch and just turn the lights on when i want to reverse? if so, how do i wire it?
its 2 wires, i think they were yellow and green/black.
any help is appreciated, normally i wouldnt care about something so minor but i need it working to get my safety check so i can register the car.
thanks HT
Old Dec 28, 2008 | 01:41 PM
RomPirate's Avatar
Default Re: prelude reverse lights not coming on!!
I'm not too familiar with JDM swaps, but are you by any chance using a 5th gen USDM harness? (Not saying others wont work, but I know the USDM one will) Check this out: http://www.preludepower.com/forums/s...33#post1916033
The wiring is for a USDM auto converted to a 5 speed.
Good luck
Old Dec 28, 2008 | 01:51 PM
92civlude's Avatar
I had the same problem on a EK that came into our shop,converted to manual. There is a 2 wire switch on top of the H22 trans. run those 2 wires directly to the green and yellow wires. it doesnt matter which one you hook up. (Its a switch) Just run 2 extra wires from the trans,thru the firewall, and to the wires inside.
Old Dec 28, 2008 | 01:55 PM
RomPirate's Avatar
I'm not sure if its the same for ALL auto to manual swaps, but (for 5th gen preludes at least) the existing gear sensor plug from the auto transmission can be wired directly into the switch on the transmission. Saves the hassle of wiring and passing the wire.
Old Dec 28, 2008 | 02:03 PM
92civlude's Avatar
The speed sensor? That is the same. But the reverse switch on an auto trans Lude is on the shifter near the center console. On a 5spd the switch is on the trans.
Old Dec 29, 2008 | 09:32 AM
92civlude's Avatar
RomPirate is right! on a 5th gen the switch is on the tranny. RED/WHT wire and WHT wire on the AT gear position switch,run those two woires to the reverse switch on the 5spd. My bad RomPirate.
Old Jan 4, 2009 | 12:10 PM
H22LUDE808's Avatar
wait. so i wire the 2 wires on the switch on the manual trans through the firewall and to which wires? cuz i have a 4th gen not a 5th. let me know and thanks for your help
Old Jan 5, 2009 | 06:42 AM
92civlude's Avatar
OK, In the console, the A/T gear position switch,on the connector, there should be a Yellow wire and next to it a Green/Black wire. These are the two wires to hook-up. also make sure fuse 13 under dash fuse is ok.
fastazzf22
Jun 22, 2009 09:51 PM
Jonathan_ED3
May 5, 2006 09:05 AM
Prelude SIR-T
Jul 15, 2005 10:28 PM
SiB16A
Apr 12, 2005 09:42 PM
EF-9SiR
11
Sep 29, 2002 04:55 PM
