turbo issues please help "d16z6-57 trim"
Old Dec 28, 2008 | 07:48 AM
912's Avatar
912
Default turbo issues please help "d16z6-57 trim"
i got my car runnin yesterday pulls great heres my problem, i'm throwin a code 1 "oxygen content"and code 12"exhaust gas recirculation system"
1. i took out the charcoaL canister?
2.cars idling up and down between 1.2 n 2.0 rpm up n down
3. reminder this is my first turbo system,at idle when i put my hand over the opening of blow off theres a vacuum should there be?
4.
Old Jan 3, 2009 | 09:33 PM
b16bri's Avatar
Default Re: turbo issues please help "d16z6-57 trim"
If the car is no tuned dont drive it and that speratic idle could be due to not being tuned and running bad AFR
Old Jan 3, 2009 | 10:09 PM
Stealthmode Performance's Avatar
The idle up and down is more than likely a vacuum line issue. Check those out. Vac through the bov at idle perfect.
Old Jan 4, 2009 | 06:33 AM
supraccordlx's Avatar
VAC leaks is causing the up and down idle, how do you have the vac lines hooked up on the wg and bov?
Old Jan 4, 2009 | 08:53 AM
evild16's Avatar
also check your iacv to make sure you don't have a bad one. That to will cause the idle issues.
93civciv
Jan 8, 2006 04:00 PM
EsCo_EsCo
Aug 21, 2005 09:21 PM
UNKNOWN_MEMBER
Aug 11, 2005 08:55 PM
Civic Racer X 7
Jul 23, 2003 07:19 AM
