new best for the hatchcrap.....STILL UNTUNED
what do ya think of this best time so far.
60ft 1.862
1/8ET 8.162
1/8MPH 85.89
1/4ET 12.807
1/4MPH 103.95
this was run at a higher elevation than i usually run at. second pass of the night broke my short shifter but my best 60 ft came from my first round loss w/ a 1.809 60ft. that was launching the car at 6k w/17psi in the tires.
60ft 1.862
1/8ET 8.162
1/8MPH 85.89
1/4ET 12.807
1/4MPH 103.95
12.8@103 w/N/A and drag radials! thats awsome!!!
man your using every last drop of HP with excellent traction to run 12.8 with a trap of only 103mph
id say its pretty much tapped out unless you find some more HP.
man your using every last drop of HP with excellent traction to run 12.8 with a trap of only 103mphid say its pretty much tapped out unless you find some more HP.
What elevation?
Thats a pretty good time regardless. Slicks are cool for racing but try it with some BFG's and if you can hit a 12.99999 N/A much props
I take it this is in an EG with between 180-190 to the wheels?
who needs BFGs when i have NITTOs that netted me a 13.004???? i moved up to slicks. much better. i built it for 12s it runs 12s, still untuned (means no dyno #s), still on pump gas, its a 92 hatch.
i only pull 1.9s w/ the nittos. i hear the BFGs r better, but never had a set and now i have the slicks i will never need a set.
