what size tube for building a header?
Old Dec 27, 2008 | 04:26 PM
boostedgsr1234's Avatar
Default what size tube for building a header?
what tubbing is used for making a b- series ss header? and where is a good place to order it from?
thanks
Old Dec 27, 2008 | 04:29 PM
E-Rok's Avatar
EPIC TUNING
Default Re: what size tube for building a header?
1.5" pipe
Old Dec 27, 2008 | 05:02 PM
what about wall thickness? and what is used for the 90 degree bends?
Old Dec 27, 2008 | 05:14 PM
Agtronic's Avatar
Do you mean a turbo header? Or an N/A header?
For the turbo header, use 1.5" Schedule 10 pipe.
For an N/A header, use 16 gauge tubing.
Old Dec 27, 2008 | 05:41 PM
E-Rok's Avatar
EPIC TUNING
yea, forgot about N/A setups.
but yea, what you said.
Old Dec 27, 2008 | 08:31 PM
thanks guys
Old Dec 27, 2008 | 08:36 PM
iv been building turbo headers, but is the 16 gauge tubing also 1.5" for a N/A header?
Old Dec 31, 2008 | 11:20 PM
JDM KID 510's Avatar
Bump for answer.
Old Dec 31, 2008 | 11:31 PM
91jdmhatchback's Avatar
For an N/A header the tube size varies alone with length depending on weather your talking a primary or secondary runner. Engine size, rpm range, head work, use, supercharged, etc. the list goes on.
It most likely won't do well unless you take these type of things into consideration.
there is a reason i havn't touched building a N/A header.
Old Jan 1, 2009 | 06:08 AM
onefstek's Avatar
Most of the design in an N/A header has to do with EVO and EVC and the time the engine spends at overlap. Dont' get me wrong, the IM, cr, cams size and red line also plays a big factor.
So to answare your questione you would have to provide more info on what you are building.
*Turbo header aka manifold 1.25" or 1.5" sch 10 or sch 40 pipe.
*N/A header 1.5", 1.626", 1.75", 1.78", 2" 14ga, 16ga or 18ga tubing, any of them, or a combination will work, depending on what you are bilding and for what purpuse.
Ashleymcfashly
Feb 19, 2016 08:49 PM
godfatheracing
K Series
Nov 11, 2012 05:24 PM
2k.civic.si
Sep 24, 2010 03:29 PM
