coolent temp issue?
Old Dec 27, 2008 | 03:04 PM
lrayford's Avatar
Default coolent temp issue?
i have a 94 accord f22b with 96k miles.... when stoped for a long time (idle) the motor gets to a littel passed half way to half (a littel more then a 1/4 i guess you could call it) and gets no "hottter" when driveing on the hwy and useing the heat i noticed that it will go down to the blue part of the gauge or even passed that... im concerned that i might do spome damage to my motor or something..my girlfriends acura integra dose the same thing
noticed that MOST of the time when on in the hwy and its not all the way cold(b.c some times its not but its rare) and then iturn the heat on then it will come down?
who knows what the promlem is???
Old Dec 27, 2008 | 03:18 PM
H22PwrdInspire's Avatar
Default Re: coolent temp issue?
Sounds like you have a thermostat that is sticking open. I would recommend purchasing a new one from your local Honda dealership and replacing it, then burping the coolant system.
Old Dec 27, 2008 | 03:32 PM
96F22B1Accord's Avatar
Could also be a condensor fan motor out as well, if the temperature is only climbing @ stops and decreasing while driving.
Old Dec 27, 2008 | 05:31 PM
YeuEmMaiMai's Avatar
check your motors and relays AFTER you replace your t-stat
1. if your car is getting warmer (Above 1/2) when idling, you have a fan problem
2. Since your car is going cold when driving around the hwy, your tstat is stuck open.
Old Dec 27, 2008 | 07:10 PM
preluderemis's Avatar
very likely to be a t-stat problem as mentioned...dont woory tho its very easy to change on a f22b
Javcolin
Mar 12, 2017 11:23 PM
dc2_dailydriver
Feb 25, 2009 07:06 PM
lrayford
Dec 27, 2008 05:49 PM
Ruben19
Jun 5, 2006 07:08 AM
ham
11
Jan 16, 2006 06:40 PM
