Rear Brake issue
Old Dec 27, 2008 | 02:56 PM
Inextricabledrvr's Avatar
Default Rear Brake issue
I know this has to be a simple fix, but I can not get the rear caliper piston to depress? I am using a C-clamp to try to get it to go down, but no luck.
Is there a particular way of depressing the rear pistons?
Old Dec 27, 2008 | 03:00 PM
m00nr0ck Si's Avatar
Default Re: Rear Brake issue
you have to rotate it in , there is a tool that you can buy at auto zone that comes in handy for this.....dont keep pressing them in otherwise you will F them up
Old Dec 27, 2008 | 04:18 PM
Thanks man! This is my first time ever changing the rears and I thought it was exactly the same as the front. Apparently, it wasn't as I couldve damaged the piston.
Thank you again
Old Dec 27, 2008 | 11:24 PM
Kronn 98SH's Avatar
Just grab a big flathead screwdriver and twist it in. No sense buying a tool when you already own one.
Old Dec 28, 2008 | 05:42 PM
I used the flathead end of a cross-range to twist it back in.
Thanks for the input guys!
Ezduzit2500
Jun 11, 2018 05:21 PM
NACvicSi
Sep 5, 2009 12:15 PM
WVhump
Acura TL, RL & ZDX
Apr 4, 2007 05:22 PM
HondaJon
20
May 30, 2003 07:42 PM
flybert
Feb 9, 2003 04:25 PM
