JDM p72 Questions
Old Dec 27, 2008 | 02:54 PM
SOHCD16y8's Avatar
Default JDM p72 Questions
I am putting a USDM 94 b18c1 into 96 Civic EX. We have an OBD1 JDM P72 ecu.
My questions is, what are the wiring differences between a JDM and USDM? Will the knock sensor wiring be the same? How about the vtec pins?
My main question however is, what does the JDM ecu send as a trigger for the IAB's? Is it ground like the USDM ecu or is it 12v?
Old Dec 27, 2008 | 02:59 PM
91TurboGSRCRX's Avatar
Default Re: JDM p72 Questions
odo1 to obo2a jumper plug in play
Old Dec 27, 2008 | 03:17 PM
SOHCD16y8's Avatar
So all of the JDM outputs are the same as the USDM? Your 100% sure that a17 is IAB and fires ground?
Old Dec 27, 2008 | 06:04 PM
kulo's Avatar
will it plug into a b18c1 motor?
what error codes will it throw up?
knock sensor?
etc?
Old Dec 27, 2008 | 06:49 PM
SOHCD16y8's Avatar
knock sensor?
etc?
Old Dec 27, 2008 | 08:15 PM
mouab18c1's Avatar
it will work for usdm cars...if your obd1 it will just plug in...if your obd2 then you just need a jumper harness from obd2 to obd1....plug and play
Old Dec 27, 2008 | 08:19 PM
SOHCD16y8's Avatar
Still looking for an answer to the question "
My main question however is, what does the JDM ecu send as a trigger for the IAB's? Is it ground like the USDM ecu or is it 12v?"
EK FLY
May 24, 2005 10:17 PM
Full-Race Henry
Jun 4, 2004 07:55 AM
mugenracer
May 21, 2003 08:39 AM
boostedcivicsir
May 16, 2003 07:10 AM
