My honda accord 92 vibrates alot when I stopped
Old Dec 27, 2008 | 08:38 AM
nizakia's Avatar
Default My honda accord 92 vibrates alot when I stopped
Hi,
I have a question that when I stop my honda accord car with my auto gear at D4 and has my foot on brakes, it vibrates alot. from inside I can feel it on steering wheel and also on bonet of car.
Can anyone give me the reason as to why I am getting this?
Thanks.
Old Dec 27, 2008 | 08:44 AM
TOO MUCH TORQUE's Avatar
Default Re: My honda accord 92 vibrates alot when I stopped
worn motor mounts. and possibly your steering column
Old Dec 27, 2008 | 09:01 AM
HondaGuy951's Avatar
completely wrong!^^
Your brake rotors are warped. replace them and u should be fine
Old Dec 27, 2008 | 10:11 AM
P_Adams's Avatar
Originally Posted by nizakia
Hi,
Thanks.
If you get a version of this vibration when you put the car in reverse, you most likely have a broken / weak motor mount or something is "grounding"* when the engine shifts position.
If (on the other hand) this does this exclusively when the brakes are applied, you have warped front Brake Rotors.
The rotors will require remachining (assuming they are still within specs) and this service can be performed either on or off the car. IF they are too thin to be remachined safely, they will require replacement (not a fun job).
P
Old Dec 27, 2008 | 05:19 PM
Originally Posted by HondaGuy951
completely wrong!^^
we both could be right.....OP's english is broken so im not sure if hes talking about IDLE vibration or braking vibration.
also in some cases, defective pads can cause violent shaking while braking.
Old Dec 28, 2008 | 10:20 PM
MagnaniEG6's Avatar
Need new mounts I have the same problem, my rotors, pads are new.
Old Dec 30, 2008 | 05:20 AM
jwicecold's Avatar
Either
*Alignment is off (most common)
*Suspension is bent, loose, or not working properly in all aspects
*Low tire pressure
*Warped/Old rotors or brake pads
Old Dec 30, 2008 | 05:30 AM
1slow02's Avatar
not to hijack the thread, but I have a related question. My girlfriend has a 92 mazda protege and when it is in drive at idle, it vibrates really bad. however if it is moving or is in nuetral, it doesn't vibrate. any idea if this would be a motor mount issue?
Old Dec 30, 2008 | 05:47 AM
P_Adams's Avatar
The quick answer, and one which will most likely be confirmed by your local tech is; Broken Motor Mount
The engine trys to reposition itself when you put it in gear. The vibation comes from it either being too close to something hard (chassis crossmember, radiator support - you get the idea).
When it's in drive (even while idling) the engine is straining against the mounts holding it because of torque. If one is broken, it (the engine) shifts out of position and vibrates against something. Putting it in neutral negates this because the engine isn't working against anything (like the axles).
Even moving (driving) can minimize this since the engine would only strain against it's mounts during hard acceleration.
P
Old Dec 30, 2008 | 06:25 AM
1slow02's Avatar
that describes exactly what is going on to a T... thanks!!
Old Dec 30, 2008 | 10:17 AM
P_Adams's Avatar
Glad I could help.
And don't worry about jacking the thread, your query forwarded the conversation.
P
Old Jan 1, 2009 | 03:01 PM
bromozee's Avatar
hey, would the broken motor mounts cause a loss in HP or TORQUE?
Old Jan 1, 2009 | 03:50 PM
P_Adams's Avatar
No, there would be no adverse effects to power output (other than a reluctance to press the issue)
Motor and Transmission mounts only effect the safe retention of the motor to the chassis and afford an isolation factor which seperates the occupants from the normal engine vibrations.
They design most Motor Mounts such that the opposing metal base plates (seperated by the iso material interlock. This to say that if the mount were to fail, the engine would still be restrained. It's movement would be limited.
P
swertepinoy
Jun 30, 2009 06:18 PM
mdowney
Jan 21, 2009 12:05 PM
ttvegas2002
Aug 19, 2005 10:42 PM
The_Gunslinger
Nov 7, 2004 11:31 PM
mrssheeps
Jul 21, 2002 06:56 AM
