RPM's going crazy on my 95
Old Aug 4, 2002 | 05:37 PM
Boughetto's Avatar
New User
Default RPM's going crazy on my 95
I have never had a serious problem with my car till now. Sometimes when i am driving, my RPM's jump up and down. Any ideas boys?
Old Aug 4, 2002 | 05:39 PM
Brandon's Avatar
Life is Suffering
Default Re: RPM's going crazy on my 95 (blue95accord)
Misfire.
Old Aug 4, 2002 | 10:48 PM
accordking's Avatar
If you don't feel the motor shaking or misfiring most likely your coil is causing your tach to jump around. Remember, you get your tach signal on the negative side of the coil..........
Old Aug 4, 2002 | 11:51 PM
b18bEG's Avatar
my roommate hasthat problem and it was his o2 sensor.. i think?....
Old Aug 5, 2002 | 01:44 PM
Chiovnidca's Avatar
Default Re: RPM's going crazy on my 95 (accordking)
V6 coils do this alot.
Old Aug 5, 2002 | 01:50 PM
John's Avatar
New User
Is it your tach or your motor? You have the early Legend motor, which had a tach problem similar to what you're describing...
Old Aug 5, 2002 | 02:30 PM
bill-71SS's Avatar
Default Re: RPM's going crazy on my 95 (DunReit)
your tach gets its signal from the igniter, not the coil. blue wire on side of igniter.
Old Aug 5, 2002 | 02:36 PM
Accord94DX's Avatar
Default Re: RPM's going crazy on my 95 (bill-71SS)
Ignition Coil for sure. Actually, it is a faulty resistor IN the ignition coil but you cannot get that seperate. You need part # 30520-P0G-A02.
Old Aug 5, 2002 | 02:54 PM
Boughetto's Avatar
New User
Default Re: RPM's going crazy on my 95 (Accord94DX)
Damn you guys are good, thanks. Also, I cannot install **** on my car, how much is the part and how much installed? What would happen if I just let it go, and not fix it? I really only spend $ on gas and oil on this car now !
Old Aug 5, 2002 | 04:57 PM
Accord94DX's Avatar
Just checked.
$577.80 for parts
$62.30 for labor
$3.12 shop fee/misc.
$37.56 Tax
$680.78 For everything.
It might be a lil cheaper depending what your dealers shop rate is. Sounds like a DIY project to me.
[Modified by Accord94DX, 6:01 PM 8/5/2002]
bertsb18hatch
Apr 19, 2008 08:14 AM
sorrule
Jun 28, 2007 04:31 PM
Integra21
Dec 26, 2006 08:39 PM
sgtroseberry
Jul 1, 2006 06:11 PM
ATgrills.com
Jun 22, 2005 07:50 PM
