Rusting Brakes help
Old Aug 4, 2002 | 05:36 PM
civicboy95's Avatar
Default Rusting Brakes help
I just put on GSR 5 spokes on my 95 civic ex coup that has 4wheel factory disc brakes. do i have worry about them rusting now? i noticed after i washed my car today, that the water on dried on the discs and turned brown. Is this normal? Thanks.
Old Aug 4, 2002 | 05:46 PM
13secondcivic's Avatar
New User
Default Re: Rusting Brakes help (civicboy95)
that's going to happen with stock rotors. the best thing to do is replace them with a slotted rotor...from Powerstop or KVR or something. they have them coated so they don't rust!
Old Aug 4, 2002 | 06:20 PM
hondafrk's Avatar
Default Re: Rusting Brakes help (13secondcivic)
all rotors will rust eventually, I just washed my car today and about 25 minutes after i had finished the rotors alreally had a small coating of surface rust on them, Its normal. Just drive to the end of the block and stop once and the rust will be gone.
Old Aug 4, 2002 | 07:02 PM
owen_the_soyboy's Avatar
Is this normal?
yes. do NOT waste time worrying about the appearance of a purely functional part of your car. brake rotors are steel, steel rusts, such is life.
and as a note, powerslot and kvr rotors are a waste of money if all you are looking for is a cosmetic upgrade for brake rotors. been there, done that. stick with stock rotors.
DC5_lov3r
May 1, 2009 02:31 PM
EK9 BEEZLER
Jul 25, 2005 04:44 AM
deviant1
19
Dec 14, 2002 01:23 PM
kkim
17
Jan 26, 2002 03:03 PM
ACIN
Dec 10, 2001 01:28 PM
