Fuel pump??
D15bd fixed my spark issue i was have. why im not geting conbustion
i dont thinkim geting fuel how would i go about checking it can i pull the fuel line an turn the car on to see if its pumping cause i have never been able to hear the pump prime an it i cant feel it turn on either..
Another quick question were is my fuel filter located?
i dont thinkim geting fuel how would i go about checking it can i pull the fuel line an turn the car on to see if its pumping cause i have never been able to hear the pump prime an it i cant feel it turn on either..Another quick question were is my fuel filter located?
Loosen the banjo bolt that connects the fuel line to the fuel rail. wHEn that loosens gas should be there in a fair amount. DO that with the fuel filter too.
ok there was fuel in the line but not much put end in a bottel an turned on the car nothing not one drop came out?? so do u think its bad?
i hear ppl talking about a Relay were is it located?
Are you ready? Well here it goes..... Look around your fuel rail there should be a bleeder valve or just disconnect the hose leading to the rail. Turn the car to the ON position and it should squirt fuel. Another way to check is to squirt starting fluid down the intake manifold ( remove air intake tube off the manifold) If it fires up then you pump is shot or the relay is shot..... Be careful though......when you do this.....
I did that i disconnected the hose leading to the fuel rail an turned the car on nothing no fuel in the cup at all.... Were is the Relay i see ppl talking about in other threads i dont have a manuel an dont have the money to buy one
relay could have something to do with it, i just replace mine becasue everytime my car was in nomal operating temperture,soon the car turn off it doesnt wants to start just turn over until the car(relay) cool down....
The fuel relay is located on the side of the fuses on the inside of the car.not exactly side to side with the fuses but to the left of it..above the hood release lever and left to the fuses.its a square black box with one bolt holding it down..if you look closetly with a flashlight it should say relayon it
ok found the main relay now i have no clicks comeing from it i pulled the coin try an i put my finger on it an nothing no clicks so i hope this is it to the junk yard i go in the morning
if your close by you can have mine for 5 bucks lol just enough to get me some in and out
Christopherian1982
Dec 31, 2008 08:17 AM
hondastudent1on1
Jul 5, 2008 02:54 PM
blinger
Sep 1, 2007 10:35 PM
