b18 c will not spark help???
So heres the story. my civic with a gsr swap was running a little wierd like it would idle at 300 to 500 rpm and under normaly driving like cruising at 1500 rmp it would act like a 2-step and jerk. and if i floored it it would be fine, and when to park it and parked it, went to start it and it wont. I have no spark what so ever. Changed ecu still wont start it primes and everything but will not start. Can any one help me?
Ditto the above^^^.
Make sure there is power going to "Distributor Assembly", [black/yellow] when ign. switch is in run, if so, check the coil and ICM.94
whizdumb
38
Apr 6, 2004 01:43 PM
