2000 Accord Check engine light on-need help
Old Dec 25, 2008 | 02:49 PM
Dogman_1969's Avatar
Icon2 2000 Accord Check engine light on-need help
I didn't even know this site or you guys was around. Thanks in advance....
My son's 2000 Accord has the check engine light on. It has been on for some time but now when the engine warms up the car just dies and won't restart for a while.
I hooked up a code reader and got these codes - P0401, P0450 & P0453.
I'm at wits end and don't know where to go other than the dealership.
Thanks in advance guys....
Dogman............
Old Dec 25, 2008 | 04:17 PM
FunnyVictor86's Avatar
Default Re: 2000 Accord Check engine light on-need help
http://www.obd-codes.com/
P0401: Insufficient EGR Flow
P0450: Evaporative Emission Control System Pressure Sensor Malfunction
P0453: Evaporative Emission Control System Pressure Sensor High Input
Old Dec 25, 2008 | 04:52 PM
What parts do I need to change or what should I do?
Old Dec 25, 2008 | 05:21 PM
P0401 Solutions:
In fixing this code, it is quite common for people to just replace the EGR valve only to have the OBD code return. The EGR valve is not always the culprit.
* Use a vacuum pump and pull the EGR valve open while monitoring engine RPM's & DPFE voltage. There should be a noticable difference in RPM's with the EGR open
* Clean out the EGR valve and/or tubing to remove deposits
* Check the voltage at the DPFE, compare to specified values (refer to a repair manual for your specific model)
* Replace the DPFE sensor (with a good quality / OEM one)
* Replace the EGR valve
P0450 Solutions:
replacing evap sensor switch and making sure that the charcoal canister that the sensor is attached to is not damaged because that would also be a possible culprit
P0453 Solutions:
make sure the fuel cap is on tight and that it is the correct type or replace the fuel cap itself
Old Dec 26, 2008 | 03:11 PM
mparack's Avatar
Dogman,
could you please tell me where you plug in the Code reader? I have been trying to figure out where the Service connector is on the Accord 2000. I have a Uk RHD 2000 Accord. Is yours RHD too? Your help will be highly appreciated.
Cheers
mparack
Old Dec 26, 2008 | 04:04 PM
Originally Posted by mparack
Dogman,
Cheers
mparack
Hey mparack,
Look ubder the dash under the left side of the steering column. Mine is just about where my left leg rubs the bottom of the dash when I'm behind the wheel.
Hope this helps......
Dogman........
Old Dec 26, 2008 | 04:21 PM
he has a euro accord right hand drive ... there are only a few places it could be ... and they're all under the dash ... driver or passenger sides and sometimes in the center console under neath the radio/dash area ...
Old Aug 8, 2013 | 08:23 PM
vmat916's Avatar
Hi,
I have the same model accord (VTI-L) but I can't locate the socket anywhere to read the codes. I even call the NRMA, road assistance guys to do it for me but the guy spent an hour or so to locate the socket but in vain.
Can you pls suggest where to go from here?
Thanks
Old Aug 8, 2013 | 08:27 PM
vmat916's Avatar
Another thing i noticed while driving the car is that the malfunction light comes on immediately when the engine is cold but after running it for 15 or so minutes, turning it off and on again makes the malfunction light to go away; I get the spark plugs replaced assuming they might be playing some role but no success. Any ideas?
batbrit
Aug 23, 2013 10:25 PM
misterix
May 28, 2012 03:27 AM
swertepinoy
Oct 6, 2009 06:40 AM
1998hondaaccord
Feb 9, 2004 12:29 PM
