ned some quick help on sensors
ok , this is a straight forward question , and would like straight forward answers
no flames or outta control posts please
anyway the intake temp sensor on the intake manifold what does it do?
will it affect performance in any way ? or just throw a code and keep the cel on .
What would you think an intake air temp sensor does?
Yeah, I know you said no smart remarks ... but if you ask a stupid question, ....
The intake air temperature is used to determine air density, so as to be able to add the right amouunt of fuel for the particular circumstances.
why is it a stupid question , becuase i dont know the answer5 to it and you do?
well thanks for your help and again thanks to this great forum for all its help
again thank you for your great help.
are you absolutely , 100% sure that this will cause me to not get enough of the right mix because it wont sense the temp in the intake manifold?
please dont guess and if you could back it up with where you found this and maybe something i could look at to see for myself.
im not saying you dont know what your tlaking about , but i want to hear more, becuase mine has been off for 4 days now and the car feels better than ever.
Sorry, I didn't mean to be an *** ... but you left yourself open for some sarcasm in the initial post.
But, more to the point.
Honda wouldn't have put it there if it wasn't needed.
Apparently you now have a CEL, so something is up (at least it knows you've disconnected this sensor).
It's been really hot out so maybe it doesn't make much of a difference since the default setting (due to the missing sensor) is probably good for the present weather conditions.
And, ... I used to work on engine control systems in my job at the office. Ed
Ummm, one last thing I just thought of.
Be careful because you might be running pretty lean ....
[Modified by Zygspeed, 8:47 AM 8/5/2002]
the cell i dont care abotu mines has been on for almost 2yrs now . i thought it might be an emissions thing , in which case i dont care about as long as it doesnt hinder the affects on my car. and yes honda does make many sensors in their cars that are not needed.
also another point , if its is needed soo much , why have i never seen and aftermarket intake mainfold with one yet?
If you've been driving around with your CEL on for 2 years, how can you be sure you're not having other engine problems that's you're just not aware of? Of all conditions that will trip a CEL, the o2 sensor would be among the least of your worries.
if your car has a problem and you need a cell to tell you , you dont belong modding cars.
i know when something is fishy and then go and chec the codes to see if its anything that i need to fix or if its just emissions crap , and then ill check all aspects of the car from there. i dont rely on themto tell me anything really, they will come on for the stupidest things. . . i have had it come on for my gas cap not being clicked the set amount of times already.
well what the hell , i ask for a straight answer to a straight question and as always these imature smart asses feel the need to **** me off instead of answer the question , i dont care about remarks, or opinions, i want straight facts and answers.
It is unfortunate that you believe that you can detect and/or diagnose every potential problem with your car without the aid of a CEL. I see expensive repairs in your future.
again thank you all for your opinions.
i will call honda direct to see if they can answer my question which still is at hand
It's a big part of the equation that the ECU uses to determine load. Without it the ECU should run rich as a safety prcaution, real rich.
Yes you need it.
LOL!
