how to replace ignition lock cylinder
Old Dec 25, 2008 | 01:17 PM
jbrune's Avatar
Default how to replace ignition lock cylinder
I have a 91 EX Accord Station Wagon and need to change the ignition lock cylinder. Can anyone provide instructions for this?
Thanks
Old Dec 25, 2008 | 02:36 PM
hondadude's Avatar
Default Re: how to replace ignition lock cylinder
First remove the steering column shroud; screws are underneath.
Unplug the switch;
Then the "collar" of the lock cylinder has breakaway bolts holding it to the column.
You can use a small chisel on the edge of the breakaway head to get it backing out.
The service manual calls for the bolts to be drilled out.
Then swap over the electrical part of the switch to the new cylinder.
re-assemble everything and go flag your 3/10s of an hour.
Old Dec 25, 2008 | 02:40 PM
kidcool1977's Avatar
SHAME ON YOU REBECCA!
Community Builder
Unplug the switch;
easy as pie. BTW to the OP if you need more info, check HONDAHOOKUP.COM they let you download pdf. manuals for accords. I am certain they have your year
pendejon
11
Nov 23, 2016 09:34 PM
Bishop1976
Sep 29, 2012 08:48 AM
viera
Mar 22, 2010 09:06 PM
bsclywilly
Audio / Security / Video
Jun 2, 2007 08:33 AM
DerangedEG
Nov 17, 2004 02:59 PM
