antenna block off plates!!
so i was on ebay an im searching for a antenna block off plate for my crx.
came in two different shapes.
heres one:
http://cgi.ebay.com/ebaymotors/88-91...Q5fAccessories
heres the other:
http://cgi.ebay.com/ebaymotors/_Car-...1%7C240%3A1318
i have never seen the first one in my life. and it the same shape as the one on my crx.
is this a legit oem block off plate?
if it is, ill bid on it.
heres one:
heres the other:
Its lagit, looks like the older Accord antenna block off plate in the top pic, the block off plate should match the shape of the factory/aftermarket antenna.
Kirk R
Kirk R
while on this topic, will these kill your radio recpetion? mine is pretty bad as it is and i have to place my hand in the antenna for it to broadcast a little better. anybody else have this problem?
these are real oem honda parts and yes your radio reception will suffer. i use an antenna that mounts inside the car from autozone. i have it on my windshield behine the rear view mirror.
since my oem antenna is broken i decided to purchase a smaller one and get a block off plate. its also an amplified antenna that has to be powered and grounded to work. it works great, no static and is hidden inside my headliner with great reception.
heres what i have:
http://www.crutchfield.com/p_12044UA...ntenna&tp=3449
how hard is it to find that type of squared block off plate? cause the oblong one looks disgusting.
heres what i have:
yea that one is not bad at all. connect it to your accessory or a remote turn on, power ant wire
Which isn't a big deal for me, I have a JDM tape deck and I have no interest in radio anyway.
All the ones I've seen look like the Civic ones(the second one).
Anyways, who cares if it's OEM or not; as long as it's clean. I just have a "dummy" antenna on my car since I use an iPod.
but the only reason i removed the oem antenna is because it snapped in half, so i bought the flat one, now i have weird stump coming out of my antenna plate.
plus when i get tired of hearing the same song over and over again with cds and mp3 player, i switch to the radio.
Another thing is that American radio is the worst radio in the known universe, and you're in the Philippines, so you're probably on a completely different page anyway.
The one you bought is way cleaner than the OEM setup anyway, it's a win-win situation.
Alcoholic93Integra
Apr 14, 2003 09:36 PM
