FS: MUST GO! B18B, B16, GSR, HG, IM, Harnesses, Inj., Block, Head, Seats
i am cleaning out my garage/storage unit. i have lots of swap parts, B16 and B18 parts, interior, some exterior, harnesses, block, head, seats, HG, IM's, mounts etc etc. BUT i haven't sorted through all of it yet. so here is what i have so far, and more will be added as i go through it all. pics of anything upon request! just PM me what you need along with your email address! IF YOU DON'T LIKE A PRICE, JUST GIVE ME A REASONABLE OFFER! PRICES DO NOT INCLUDE SHIPPING COSTS, SO PLEASE BE REASONABLE WITH YOU'RE OFFERS! THANKS!
**NEW PARTS ADDED--> 3/10/09**
Skunk2 Pro IM for GSR, brand new never installed---> SOLD
NEW thermal IM gasket for GSR IM, NOT Hondata---> $35
NEW thermal TB gasket for B/H series, 70mm size---> $15
NEW OEM DOHC VTEC headgasket, 81mm bore size---> SOLD
B series alternator bracket set with bolts--> SOLD
B series timing side engine mount with 2 studs---> SOLD
B series timing side engine mount with 1 stud (OBD0 i believe, x2)---> $8 each
Gorilla chrome lug nuts, new condition, 12mmx1.25 size (not sure if it fits Civic or Integra studs since i never tried them), 14 are Gorilla and 2 are not but look nearly identical. i'm not sure how i ended up with 2 oddballs. LOL i got these awhile back with a set of wheels and never used them. included is the socket attachment to torque them down---> $10 for the set
**NEW PARTS ADDED--> 2/9/09**
97 LS underhood fusebox, next to battery, includes all inside fuses and cover--->
$8
97 LS Fuel Rail/Injectors/Fuel Line (from filter to rail)/FPR set, no damage, all OEM parts---> $45
97 LS engine harness, uncut, no damage---> SOLD
97 LS Throttle Body, includes original TPS and MAP, ready to install---> SOLD
97 LS OEM Alternator---> $25 (worked when pulled, still spins freely)
97 LS Throttle Cable, from pedal to TB, uncut---> SOLD
97 Integra OEM battery cables, from fuse box to battery, and from battery to starter----> $6
Integra B series coolant passages (2), from water pump to thermostat housing, one has 1 neck on it and the other has 2 necks on it---> $5 each
97 Integra cruise control box, underhood unit, includes uncut throttle cable---> $20
97 Integra timing belt cover set, all 3 pieces---> SOLD
Integra tranny housing/clutch/flywheel bottom cover piece, bolts from block to the tranny housing to cover the bottom of the flywheel/clutch, no damage---> SOLD
Integra coolant passage control piece/valve for firewall, allows coolant to flow through the firewall to the heater core inside under the dash, no damage, includes hose---> $10
94+ Integra OEM intake tube and airbox with used filter---> $10
**NEW PARTS ADDED 1/21/09**
GSR OEM Flywheel---> SOLD
97 Integra LS Climate Control Dash Unit--worked fine when pulled, complete---> SOLD
97 Integra LS ABS Unit--under hood unit for line distribution etc---> $15
99 Integra GSR Rear Brake ABS sensors and cables--Left and Right sides, mint condition, uncut---> $20 for the pair
B series DOHC VTEC lower tranny to block bracket (larger silver piece), NIB---> $25
B series lower tranny to block bracket (small black piece), NIB--$15
OEM Resistor Box---> $10
B16 IACV---> $10
**NEW PARTS ADDED 1/16/09**
B Series Axle/Halfshaft set--aftermarket axles, used 6 months, very few miles (500), perfect condition other than surface rust on the outside, comes with axle nuts.
Left side axle is Female to Male. comes with Male to Male halfshaft. complete setup
SOLD
AEBS B16/TypeR intake manifold--includes fuel rail studs, TB studs, IAT sensor, throttle linkage bracket, NOT ported---> SOLD
OEM GSR cams--US spec, complete with gears, bolts and keys---> SOLD
B16A Timing Covers--upper inner, upper outer, lower outer---> SOLD
OEM B Series starter for Hydro tranny---> SOLD
B Series OEM Injectors OBD2--240cc, set of 4---> $30/set
DOHC VTEC spark plug cover--lots of scratches!---> SOLD
**NEW PARTS ADDED 1/7/09**
B Series Engine Mount, Upper Tranny--no damage---> SOLD
B Series Engine Mount, lower tranny piece that the lower front tranny mount connects to, 3 bolt piece with the stud for the lower mount, a little corrosion on it but no damage, currently only 2 bolts and 3 washers included (i have to find the other bolt in one of my boxes)---> SOLD
B Series Rear Engine Mount--no damage or tears in the bushing---> SOLD
94+ Integra Front Lower Subframe Brace (OEM)--no damage, NO bolts included---> $20
97 Integra OEM Vacuum Canister, with all hoses, no damage, firewall mounted- SOLD
94+ GSR OEM fuel rail, with OEM fuel pressure regulator---> SOLD
B18 Block Coolant Passage, with 2 necks on it---> $6
B16A OEM Crank Pulley, for A/C, Alternator, PS pump, includes bolt and washer but no key---> SOLD
B18 IM bracket, below IM to connect it to the block, no bolts included---> $8
94+ OEM GSR Valvesprings (16 Intake, 8 Exhaust), 100K on them, from a stock engine, no damage---> SOLD
97 Integra Front "Mud Guard", connects to the front bumper and wheel well liners underneath the radiator to keep dirt and water out, no damage---> SOLD
(i have the wheel well liners too if you need all 3 pieces!)
97 Integra OEM Radiator, includes both fans and wires, complete, but it's from an AUTO Integra so it has extra "ports" in it, some bent "fins" but no real damage to it, includes the upper main coolant hose, and some other lines too ---> SOLD
97 Integra Battery Tray, includes the OEM partial plastic battery cover and the 2 mounting rods to secure the battery in place (but no tie down bar), no damage
---> $12 for the set
APC 94+ Integra Clear Corner light (only one, i believe the right side), used---> $5
97 Integra LS Brake Master Cylinder, with complete reservoir attached, unknown internal condition (not sure if the seals are still good, maybe use as a core exchange)
--> $5
B Series OEM 270cc Accord Injectors, Cleaned and Balanced with new O-rings, then used for only 500 miles to break in an engine while i waited to install my 440cc injectors and Hondata S100, work perfectly!---> SOLD
**NEW PARTS ADDED 1/1/09**
Civic 92-95 Rear Lower Control Arms (L&R)--bushings still intact, NO sway bar
mounting---> $20/pair
Integra 94-01 Rear Lower Control Arms (L&R)--sway bar mounting, center bushing on right side needs to be replaced, perfect for new race bushings or just replace the one bushing with OEM---> $20/pair
00 GSR Head bolts--no damage, torqued once, all 10---> $12/set
B Series Rear Engine "T" Mount (x2, from 97 Auto and 95 Manual)---> $10 each
------B16/B18C PARTS------
DOHC VTEC OEM HG--NEW in package, 81mm bore---> SOLD
'00 SI Engine Harness--mint, no cuts--> SOLD
B16A OEM IM--NO sensors, NO TB and NO Fuel Rail or injectors---> $20
B-series OEM Fuel Line (Filter to Rail)--GSR, comes w/rubber sleeve to protect--> $15
DOHC VTEC Spark Plug Cover--OEM Silver, great condition, 2 small scratches-->
SOLD
OEM GSR Main Cap Bolts--All 10, NEW in packaging--> $30
GSR Oil Windage Tray and Oil Pickup--> SOLD
------Integra/B18B PARTS------
'97 B18B half-shaft--no damage, male to male---> $20
'97 Integra Front Fender/Wheel-well Liners---> $25 for the pair
Prothane Rear Trailing Arm Bushing Set for DC/EG--BNIB--> $30
------Civic/EG PARTS------
92-95 Civic OEM Front Suspension Forks (L&R)--no damage--> $10 for the pair
92 Civic DX Hatch gauge cluster (no tach)--102,790 miles, everything works--> $10
92-95 Civic Hatch REAR Fender Edge Liners--NEW in OEM packaging--> $10/pair
-----97 LS Parts Below-----
B18B Block--approx. 150K on it, all stock, never modified, still fully assembled, complete w/pumps, torque converter, oil pan, all internals. i see no damage at all and the crank still spins easily, BUT i planned on tearing it down and rebuilding it. i have not had time to take the oil pan off and properly inspect it.---> SOLD
B18B Head--removed from the above block, same condition/mileage, no known or visible damage to anything, includes valve cover and all internals, still assembled. (also have the IM if needed)---> SOLD
B18B Auto Tranny, complete w/starter etc---> $50
B18B OEM IM w/sensors---> $20
B18B Dist. (OBD2) w/used cap and rotor---> SOLD
B18B ECU (OBD2), *Auto*, virgin---> $25
Tan Front Seats, very good condition, no known tears or stains---> SOLD
Tan Door Panels, good condition, w/OEM tweeter, power controls---> $20 for the pair
Tan Center Console, Glovebox, OEM CD player (no code)---> MAKE OFFER
Tan Steering Wheel w/complete steering column, from airbag to steering rack, all sensors etc etc, nothing missing or damaged---> $100
Tan Pass. Side Airbag---> $30
Green Rear Hatch Spoiler, OEM, paint is in good condition, uncut wires---> $30
MANY MORE PARTS TO COME! I'LL UPDATE REGULARLY WITH NEW PARTS!
THANKS FOR LOOKING!
$8
B16 IACV---> $10
SOLD
--> $5
SOLD
THANKS FOR LOOKING!
thanks for the bump! all PM's returned... if for some reason i missed someone, just hit me up again. thanks!
