How much oil for our motors d series b series k series
Old Dec 24, 2008 | 09:56 AM
acmoc's Avatar
Default How much oil for our motors d series b series k series
hey,
I just read though a shop manual I bought, it says the d16 takes only 3 qts.
I always put in around 31/2 for it to reach the upper dot on the dip stick.
am I putting in too much, where should the oil mark be on the dipstick?
For example: d16a6 o----*-o-----------------P <- dipstick
I know too much oil can cause leaks so I just wanted to ask.
add other engines to if you know them.
Thanks
Old Dec 24, 2008 | 11:30 AM
D16SiHatch's Avatar
Default Re: How much oil for our motors d series b series k series
D-Series
D16A6
For Engine Overhaul 4.0 L (4.2 US qts. 3.5 Imp.qt)
For Oil Change, Including Filter 3.5 L (3.7 US qts. 3.1 Imp.qts)
For Oil Change, Without Filter 3.0 L (3.2 US qts. 2.6 Imp qts.)
D16Z6
For Oil Change, Including Filter 3.3 L (3.5 US qts. 2.9 Imp.qts)
D16Y7
with filter 3.6L (3.8 Qt)
without filter 3.3L (3.5 Qt)
engine overhaul 4.3L (4.5 Qt)
D16Y5 and D16Y8
with filter 3.3L (3.5 Qt)
without filter 3.0L (3.2 Qt)
engine overhaul 3.7L (3.9 Qt)
B-series
B-series (B18A/B non-vtec)
Capacity Without New Filter: 3.7qt
Capacity With New Filter: 4.0qt
Capacity After Overhaul: 4.9qt
B-series (B16A2 vtec)
Capacity Without New Filter: 3.9qt
Capacity With New Filter: 4.2qt
Capacity After Overhaul: 5.1qt
B-series (B18C1 and B18C5)
Without Filter Change 3.6L (3.9 Qt)
With Filter Change 3.9L (4.2 Qt)
After Overhaul 4.8L (5.1 Qt)
K-series
RSX, K20A3,
Including Filter 4.4 US qt (4.2 liters)
Without Filter 4.2 US qt (4.0 liters)
RSX Type-S Models, K20A2, K20Z1
Including Filter 5.0 US qt (4.7 liters)
Without Filter 4.8 US qt (4.5 liters)
2007 Civic Si, K20Z3
At Oil Change 4.2L (4.4 Qt)
At Oil Change including Filter 4.4L (4.6 Qt)
After Engine Overhaul 5.5L (5.8 Qt)
Old Dec 24, 2008 | 01:04 PM
acmoc's Avatar
wow.
Thanks allot, I guess I was about rite then huh.
thanks, did you google that? I found nothing.
Old Dec 24, 2008 | 04:03 PM
carnz98gsr's Avatar
i always fill mine 4quarts, but then again i have 3 oil leaks hahaha. waiting for my parts to come from honda so i can rebuild this sucker
Old Dec 24, 2008 | 04:26 PM
crx2nr822's Avatar
I didnt know too much oil can cause leaks I just did an oil change yesterday and put 4 quarts in my d15 (doh!) and I have a minor leak already, and im pretty sure everything was tightened down good.......ill have to check again. Where exactly does the leaks come from? The drain plug and/or oil filter?
Old Dec 24, 2008 | 04:30 PM
carnz98gsr's Avatar
no, you can blow a seal with too much oil in the engine, but generally thats an excessive amount. a couple tenths over isnt gonna destroy it. and if you know you have a leak i'd advise to overfill it just a bit, just keep checking on it.
Old Dec 24, 2008 | 10:42 PM
D16SiHatch's Avatar
Originally Posted by acmoc
wow.
i have dealership access to ALLDATA online. it's pretty much amazing
Old Dec 25, 2008 | 12:48 AM
Stunna MIKE's Avatar
So do I!
Old Dec 25, 2008 | 12:36 PM
JOE BD-0's Avatar
^^^^Can you guys share some of that alldata love?????
philosofy1
12
Sep 29, 2005 06:24 AM
2000CX
23
Oct 24, 2003 06:42 AM
sloweh3
Jul 19, 2003 05:05 PM
Goy091
20
Mar 17, 2003 05:20 PM
MikeSarr_GSR
Dec 1, 2002 04:34 PM
