obdo jdm b16 code 4
Old Dec 24, 2008 | 09:49 AM
trevorjohn88ef's Avatar
Default obdo jdm b16 code 4
car starting bogging out about a week ago threw a code, the nexxt day it was fine, went out today and started doing it again, ecu says its running a code 4, which is the cam angle sensor, also the dizzy is squeaking really loud alot, just replaced the dizzy about 2 months ago, but i used the same cap from my old one, so i pulled the cap off the dizzy and it was cover with brown dust, just trying to figure out how to fix this, any help is appreciated thanks
Old Dec 24, 2008 | 06:06 PM
dephtone's Avatar
Default Re: obdo jdm b16 code 4
Cam angle sensor is inside the dizzy. There are 3 wires that hookup in there, Cam Sensor, Crank Sensor and TDC sensor... Sounds like you need a new dizzy, if replacing the cap doesn't work, but I wouldn't waste my time spending money on a new cap as it won't help the sensor inside the dizzy.
Old Dec 24, 2008 | 07:28 PM
JDMatt3's Avatar
second that, replacing the distributor would prolly be your best bet.
Old Dec 24, 2008 | 08:47 PM
well i just bought it from hmotors like 2 months ago, im pissed, anyone know where i can get a NEW one?
Old Dec 24, 2008 | 10:15 PM
schock3's Avatar
bump
Old Dec 25, 2008 | 12:51 PM
bump again
Old Dec 26, 2008 | 02:55 PM
Je2RiT's Avatar
yes you have to replace the dizzy. the shaft bearing is going out.. basically eating itself away.. JUST had the same problem you have. if you just bought it. Take it back and get a new one. they should give a new one up.. (Usually have a 1 year warranty for remanned dizzys)
dubs97integ
Mar 9, 2009 10:31 PM
kwizical
12
Mar 10, 2008 08:05 AM
traybert2003
Feb 8, 2007 09:41 AM
civicflow
Mar 3, 2006 11:30 AM
gvillehnut
Feb 21, 2003 12:00 AM
