motor bogging while you drive
Old Dec 23, 2008 | 07:27 PM
punisher003's Avatar
Default motor bogging while you drive
i have gsr motor with a type r built head the problem is it boggs when you floor it and some times it run goods it feels like something is restricting it from going can yall help me out
Old Dec 24, 2008 | 07:09 AM
4drEF's Avatar
Keyboard Humorist
Default Re: motor bogging while you drive
Could be a bunch of things ranging from detonation, too much fuel, air flow, igntion timing, tune, cam timing, etc.
if you aren't throwing codes I think maybe try double chcking your cam timing, set up your igntion timing differently, higher octane gas, and ensure your sensors (like TPS) are all adjusted right and are in spec.
Old Dec 24, 2008 | 04:37 PM
carnz98gsr's Avatar
give us some more info about your setup and check everything like 4drEF mentioned then report back
sublimenerd
Sep 8, 2006 09:54 AM
scUba-stEve
13
May 15, 2005 08:47 PM
*Boostwerks*
Aug 14, 2004 01:42 PM
brockscivic
Jun 25, 2004 07:44 AM
