Disassembling B20, down to crank, help!
Old Dec 23, 2008 | 06:36 PM
topherchris's Avatar
Default Disassembling B20, down to crank, help!
Ok, so I got everything off, the only thing on the block still is the rear main seal, oil pump, crank, and dipstick tube....pistons are pulled and everything. So my question is how to get the rear main seal and oil pump off, i have them both unbolted and ive tapped on them a little but didn't want to really pound on them for fear of damaging them, so how do you remove those, and is there a way to remove the oil dipstick tube before sending the block off? And btw ive searched for a little over an hour now and cant find what i need.
Old Dec 23, 2008 | 07:47 PM
iwanttokillgod's Avatar
Default Re: Disassembling B20, down to crank, help!
hit it pretty ard with a rubber mallet
Old Dec 23, 2008 | 07:48 PM
srmofo's Avatar
IF you have all the bolts out then the pump is just stuck on there with rtv, tap it a little more...dipstick tube just pulls out, but its usually a bitch
Old Dec 23, 2008 | 10:14 PM
awesome! came apart like a dream (with the exception of oil flying all over my white appt walls) beating it harder always works, thanks a lot!
88CRX_SiR
Apr 5, 2015 03:17 PM
mattbatson
Mar 30, 2009 07:23 PM
slowassciv33
Apr 22, 2006 05:24 AM
NSTY Z33
Aug 4, 2004 10:55 PM
NWHybrid
Jan 23, 2004 10:19 PM
