Password: JDM Dry Carbon Fiber/Kevlar Cooling Plates !
FREE SHIPPING ON ALL PASSWORDJDM PRODUCTS!!
CARBON COOLING PLATE FOR 2006+ CIVIC 4DR NOW AVAILABLE!!
2006+ CIVIC 2DR COUPE COOLING PLATE WILL BE AVAILABLE VERY SHORTLY!!
CLICK HERE FOR MORE INFO!!
Kevlar version for the 2006+ 4dr also now available!!
The cooling system is a vital component of your EG Civic's operation. The radiator needs constant airflow, with minimum turbulence, to be as efficient as possible. Unfortunately, gaps in the structure around the radiator allow air to escape, resulting in lost efficiency. We have designed the Dry Carbon EG Civic Radiator Cooling Plate to eliminate this problem. By preventing air to escape over the top of the radiator, these cooling plates allow a maximum amount of airflow directly to your radiator, resulting in reduced coolant temperatures during aggressive driving.
Not only will you gain cooling effeciency with the PWJDM radiator cooling plate, you will also clean up your cluttered engine bay. Unlike the other cooling plates out there, ours is super light, often more than twice as light as a clear coated carbon versions.
Password:JDM Dry Kevlar Cooling Plate (EG '92-'95 Civic)
Password:JDM Dry Carbon Cooling Plate (EG '92-'95 Civic)
Password:JDM Dry Carbon Cooling Plate (EK '96-'00 Civic)
Password:JDM Dry Kevlar Cooling Plate (EK '96-'00 Civic)
PM me for special HT Pricing.
