stressing car frame
Old Dec 23, 2008 | 11:53 AM
BLU CIVIC's Avatar
Track Advocate
Default stressing car frame
alright, my house has one of those slanted curds and a steep driveway...everyday when i leave, i turn at an angle to so that the car won't scrape on the curb...the problem with that is that coupled with the angle of the driveway i always end up with one or two wheels off the ground. i know this is causing added stress to the frame of the car, so is there anything i can do about strenthing the frame w/o a roll cage or anything as drastic as that? happens every time i back out the driveway and parking on the street isn't an option.
Old Dec 23, 2008 | 01:00 PM
ED9man's Avatar
it doesn't matter
Old Dec 23, 2008 | 02:49 PM
SpeedSin's Avatar
Default Re: stressing car frame
Dont think this is something that you should worry about. Your not applying significant force for any extended amount of time. The chassis of your car is designed to flex (to a small degree). You said....curds.
Old Dec 23, 2008 | 03:08 PM
BLU CIVIC's Avatar
Track Advocate
Originally Posted by SpeedSin
You said....curds.
i did...lol
ok...i won't worry about it then
Old Dec 23, 2008 | 05:13 PM
~sp33~'s Avatar
EFB055
Are you on stock suspension?
Old Dec 23, 2008 | 05:28 PM
SpeedSin's Avatar
nah, hes got dros. j/k...idk
Old Dec 23, 2008 | 05:41 PM
BLU CIVIC's Avatar
Track Advocate
D2's...i know it's b/c the car is dropped
Old Dec 24, 2008 | 03:48 AM
~sp33~'s Avatar
EFB055
I'm dropped a fair few inches, and i never lift a wheel in the air.
Are you just using the stock SI sway? Pretty cool if so.
Old Dec 24, 2008 | 04:28 AM
BLU CIVIC's Avatar
Track Advocate
yeah i'm using the stock sway bar
i'm finding that backing in helps...but i can feel the front passenger wheel come up for a second...
Old Dec 24, 2008 | 07:13 AM
4drEF's Avatar
Keyboard Humorist
It's normal.
Putting on a squishy suspension and removing the sway bars too might keep you from lifting a wheel.
Roll cage or something along those lines to tie the subframes together is about all you can do to spread out the stress from the chassis twisting
Ripcord990
Jan 10, 2014 08:03 PM
Smurf BNMS
39
Oct 7, 2005 06:03 AM
97akwerd
Aug 5, 2005 02:42 AM
johng
Jul 13, 2001 09:53 PM
