Cel issue!!!!!
I have a jdm b16 in a 89 hatch thats obd1. Its throughing codes 12 and 41 with a jdm p30 b16 ecu. please help me. im going to take care of the code 41 with a new o2. Someone help me with the code 12. please help me out. BTW The ecu is stock. thank
yes code 12 is the egr lift sensor which i dont have on a b16. The code 41 is the primary o2 sensor and its been fixed. so i just have to get rid of the code 12. thanks
the ecu is stock obd1 p30 and it doesn't even have a wire going into port a 11 on the obd1 side of the jumper harness. i don't know how this could be sending the code 12 which is for the egr selonoid valve. please help me.
hmm thats wierd because your running a jdm ecu with jdm motor....try using a usdm b16 ecu...ill do some research also
this is weird because i've never seen a EGR solenoid on b series...are you sure thats a b16 ecu? well not any b series obd1 or obd2 cars...check this page out...could help out a bit...cuz if it doesnt show up when using the gsr ecu then im thinking your using an obd0 ecu...http://hondaswap.com/hybrid-eg-ek-dc...wiring-142906/
https://honda-tech.com/forums/showth...2122763...read this thread....i got bored so researched for you..hopefully it will help you somehow...
