Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
2003 V-6, Replace P.S. Pressure Hose
Old Dec 23, 2008 | 07:05 AM
joeramirez's Avatar
Default 2003 V-6, Replace P.S. Pressure Hose
The pressure hose on my Power Steering is leaking. What do I need to remove to access the fitting at the back of the engine on the rack I believe. Does anyone have the section from the service manual that would show in detail how to do this.
Old Dec 23, 2008 | 07:50 AM
tortuga89's Avatar
Default Re: 2003 V-6, Replace P.S. Pressure Hose
is the outlet or the inlet
Old Dec 23, 2008 | 08:28 AM
joeramirez's Avatar
The one that is pressurized that goes down behind the engine.
Old Dec 23, 2008 | 12:29 PM
fiveten's Avatar
there are 2 10mm bolts that hold it on the subframe, one on the valve cover and 2 on the pump. Don't forget to disconnect the p/s pressure switch. It is a 14mm flange on the rack and pinion. You will have to disconnect the exhaust y pipe to access the 4 14mm bolts that hold the rear engine mount. After you remove the mount bolts you lift the engine to gain space to get the hose out from under the mount. Reverse to reinstall hose.
Old Dec 23, 2008 | 12:58 PM
joeramirez's Avatar
thank you.
Old Dec 23, 2008 | 01:47 PM
tortuga89's Avatar
good luck with the house
Mishako129
Jan 30, 2013 08:54 PM
composter7
Jan 13, 2010 04:26 PM
jeremyrocksursox
Feb 22, 2009 09:25 AM
