What Kind of harness/ and what this wire???
Old Dec 22, 2008 | 07:25 PM
laziebun's Avatar
Default What Kind of harness/ and what this wire???
So the two first picture are plugs that connects to the ecu..I was woundering what kind of harness this is GSR ITR...etc.....
31P
25P
Second this wire was cut and i have no clue what its for. i've search and look in my Haynes book and nothing.
Yellow with Red stripe
Old Dec 23, 2008 | 03:35 AM
laziebun's Avatar
Default Re: What Kind of harness/ and what this wire???
someone has to know..
Old Dec 23, 2008 | 06:04 AM
fcm's Avatar
fcm
Old Fart
Hard to say, there is more then one yellow/red lead in the car.
Engine oil pressure switch lead is yellow/red running to gauge assembly and ICU.
There is a yellow/red running from heater control unit, [vent switch] to mode control motor.
The radio harness has a yellow/red, [radio acc. power].
Onr of the leads from the manifold absolute pressure sensor is yellow/red but changes to yellow/white before connecting to ECU/ECM (VCC1), 98 Integra only.
All but the above seem to be common to 94-98 Integra. 94
Old Dec 23, 2008 | 06:18 AM
laziebun's Avatar
THATS IT!! its for the oil pressure....wow i cant believe i didnt catch that.
One more question on top of what i've already ask....if im not using the o2, oil pressure, and knock can i just take the connectors off and tape off the pins and save it in the engine harness sleeve? Im doing a mild wire tuck and i dont want extra connectors hanging around, but want to save for later if i needed it.
Old Dec 23, 2008 | 06:24 AM
laziebun's Avatar
Haynes book does not have a oil pressure in their wire diagram!
Old Dec 23, 2008 | 11:22 AM
fcm's Avatar
fcm
Old Fart
What Haynes are you looking at?
My Haynes #42025 shows EOPS on page 12-45. [94 Integra] and page 12-47, [95 - 98 Integra]. 94
Old Dec 23, 2008 | 01:45 PM
laziebun's Avatar
I also have the 42025 i see the EOPS on page 12-47 but not on 12-45
Old Dec 24, 2008 | 06:22 AM
Blown90hatcH's Avatar
31P
25P
That is an OBD2b harness for sure. At first I had to check to make sure it wasn't an OBD2a with automatic connectors, but the wires are not in the right location for the auto functions on the B plug for it to be OBD2a. Assuming nothing has been modified, that looks to be a 99-00 Si harness or TypeR. I don't believe it is a GSR harness because the IAB control solenoid valve wire that is at B16 (25P connector) is not there. I don't think it is a LS harness because it looks like (hard to tell from these angles) that the vtec wires are there. Given the location on the Yel/Red it is probably to the oil pressure switch dummy light.
But I am certain that is an OBD2b harness.
Old Dec 24, 2008 | 07:03 AM
laziebun's Avatar
you are the man.. if you ever get into a fight i got your back!
kotykotlas
Audio / Security / Video
Apr 16, 2018 08:13 PM
89SiZero
Jul 1, 2014 09:02 PM
CERRITOS.562
Sep 27, 2007 08:20 AM
MilanoCivic97
Feb 4, 2007 06:53 AM
Neren
15
Oct 5, 2005 05:56 PM
