Why doesnt my CRX like its factory ECU?
Old Dec 22, 2008 | 06:22 PM
SpeedSin's Avatar
Default Why doesnt my CRX like its factory ECU?
So I have been running a PR4 on my Si (no major mods) now for years. Every year when its time for emissions I re-install my PM6 to get the car to pass. Well this year I do the same, and the car runs like hell after putting on the PM6. It idles sporadically, starts to smoke and bucks and hesitates at low to mid range throttle. So i tried another PM6 from a friend's car...samething. Then I tried A pg7 I used to run, the car did better but was still hesitating and bucking slightly under low to mid throttle application. So what the hell is this? Why will my car only run well with the PR4? Input would be appreciated.
Old Dec 22, 2008 | 07:13 PM
crxcess's Avatar
Default Re: Why doesnt my CRX like its factory ECU?
doesn't the PR4 run richer? I'm no expert, but I would think that it has something to do with a poorly functioning sensor somewhere.
Old Dec 22, 2008 | 07:38 PM
Crx Jimmy's Avatar
something is wrong, is everything stock?
Old Dec 22, 2008 | 09:27 PM
soodominican's Avatar
Why are you running a pr4 on a d16? or a pm6 on a b18a? Why do you need to replace your ecu to pass emissions? do you live in california? i have a pr4 on my ls though i should have a p75nand pass emissions in PA and NYC
Old Dec 23, 2008 | 02:44 PM
SpeedSin's Avatar
Yeah the PR4 runs richer. Yup everything is stock. The reason I put on the PR4 was curiousity. It makes the d16 pull great. When I have the emissions checked with the PR3 the nox are thru the roof. I do have a chronic code 1 that refuses to go away (tried 3 different O2 sensors [NTK, Denso, Bosch]). Otherwise the car runs great as long as the PR4 is installed.
Corksil
23
Jul 14, 2011 05:59 PM
turbogsr181
Jul 21, 2006 10:22 PM
wid326
26
Aug 19, 2004 07:21 PM
bluedelsol
Jul 28, 2003 05:13 PM
civicsport
Aug 16, 2002 03:42 PM
