street slicks for ls/vtec w/ls tranny
im looking for a tire that hooks as best as possible with alittle over 500whp and an ls tranny. i was looking at the m/h 235/60/14 and then i looked at the gear calculator on mfactory and it says 4th gear will do 156mph at 8500rpm. Is that accurate to say? i wont be ever taking it that fast on the street. To me with that gearing, it seems the tire might be to tall maybe? I want a tire that makes my 4th gear top out at a little over 140mph or so.
also i was looking at the bfg 215/60/14's. that would put me at the mph i want in 4th. right now i have vx wheels with new 215/50/13's and it spins till 130+mph. will any drag radial really help me that much on the street? I have a set of lenso's for the track, just looking for a better street tire.
I'm in the same boat. running right at 500whp but kseries. I tried falken rt615's= no traction at all...bfg's=no traction until top of third gear. third gear pull on highway just breaks them loose. I was looking into MT street radials but they were on backorder or something like that for a while. I'm also wanting to get a good street tire but mine is for 16'' wheel.
M/T 235/60 15 works very good, dead hook on a second gear roll on with 480whp ( just need to warm them up first ). Try too get a GSR or Type R gearset.
You need to put a shorter geared tranny in that thing so you can run a larger tire. The 235/60/14 MH bias ply tire is great with a b16 gear set. If you stick with the LS, you are going to either be stuck in the wrong part of the powerband or be stuck using a smaller tire that will spin like hot cakes.
Colin what chassis was this in? Also could I just put itr 3rd and 4th in since that's the only gears I'm worried about? I def still want the ls 5th
LSVTEC 91 Civic
18
Oct 31, 2005 08:17 AM
