is there any reason to have a camber kit if your car is not lowered
Old Dec 22, 2008 | 12:39 PM
khronicboy420's Avatar
Default is there any reason to have a camber kit if your car is not lowered
i have a 95 accord and i ordered a camber kit cause i lowered my car but im going back to my stock springs now so i was wondering if there was any reason i should still put the camber kit on even though my car wont be lowered?
Old Dec 22, 2008 | 12:47 PM
P_Adams's Avatar
Default Re: is there any reason to have a camber kit if your car is not lowered
IF there are no indication of the crossmembers, control arms or other suspension components being bent, NO.
If (however) the camber angle is excessive, then camber kits make sense.
Camber kits make sense when the canber is out of spec, regardless of the reason.
P
Old Dec 22, 2008 | 02:14 PM
flight50's Avatar
like the above. in short no. if you do however think you might lower and your degree is -2 or more, then it can help. your toe is more important to have a 0 than your camber. alot of us are lowered and don't require a camber kit. just be aware that without alignment correct that you may go thru tires quicker. - camber can actually be good as long as its not extreme.
Old Dec 22, 2008 | 07:10 PM
how can camber be good? and also my car is lowered on H&R coilovers,and the front is raised about half way but the back i have set up to the highest it will go. is this normal?my car sits level,actually the back is just slightly lower than the front. please help
Old Dec 22, 2008 | 08:13 PM
accord_raffi's Avatar
the relation between caster, camber, and toe are all handling related. With negative camber (from lowering a car), you have better cornering. However, like all things, you can over do it and just wear your tires out for no reason. I have just shy of a 2" drop and i didn't bother with a camber kit. the tire wear is fine too.
Old Dec 23, 2008 | 04:58 AM
P_Adams's Avatar
Short version:
Have the original springs installed
Have the alignment checked
If it's within specs, congratulate yourself and move on, or
If either the Camber OR Caster are NOT equal on both sides, they must be corrected.
Uneven camber will pull towards the higher value
Uneven caster will pull towards the lower value
Incorrect toe will either
1) Toe-out causes the front end to wander
2) Excessive toe causes tire wear quickly
3) Toe-out causes scuffing around corners
P
Old Dec 23, 2008 | 11:05 AM
thank you thats helps alot
Old Dec 23, 2008 | 11:12 AM
P_Adams's Avatar
It's a difficult subject. Glad we could help.
P
Accord-Guy
Suspension & Brakes
May 12, 2010 03:29 AM
FLACO EM1
Nov 27, 2008 01:39 PM
BJA86
11
Sep 2, 2007 01:00 PM
b18LS
Suspension & Brakes
Apr 18, 2007 06:05 AM
631 Teggy
Jan 18, 2003 07:38 AM
