ADVICE: Can anyone tell me of some of the problems I might have...
Old Aug 4, 2002 | 09:27 AM
Turtle's Avatar
Default ADVICE: Can anyone tell me of some of the problems I might have...
Installing a Mugen twinloop on a stock cat? I know it will be a pain to get the bolts off, but is there anything else I need to consider when installing? I should be getting everything in this week, and throwing it on over the weekend. Just looking for some people who have ran into "gotcha's" with this setup, to make the install a little smoother, and if there are anything I will need. Thanks guys...
Brandon - who is all too familiar with we-todds, but prefers the smooth installs
Old Aug 4, 2002 | 09:31 AM
B2FiNiTY's Avatar
Default Re: ADVICE: Can anyone tell me of some of the problems I might have... (401-2001)
Nothing that I know of. Good luck with the install
Old Aug 4, 2002 | 09:37 AM
CPR's Avatar
CPR
The only part that sucks is that the bpipe is one piece as opposed to the easier to install 2piece bpipe. Overall, there shouldn't be any unexpected difficulties.
Old Aug 4, 2002 | 09:40 AM
B2FiNiTY's Avatar
Default Re: ADVICE: Can anyone tell me of some of the problems I might have... (CPR)
Just get a friend to help hold the exhaust.
Old Aug 4, 2002 | 09:44 AM
SoCal ITR's Avatar
Default Re: ADVICE: Can anyone tell me of some of the problems I might have... (B2FiNiTY)
Old Aug 4, 2002 | 09:47 AM
dohcsideSi's Avatar
along as you have some heat... propane touch for example...you shouldn't have any problems, i'm not sure about the mugen but swaybar clearence might be a problem w/ an a/m bar
Old Aug 4, 2002 | 12:30 PM
Turtle's Avatar
Default Re: ADVICE: Can anyone tell me of some of the problems I might have... (SoCal ITR)
Chris you there??? Right on!
Old Aug 4, 2002 | 12:34 PM
ZygSpeed's Avatar
Brandon -- if your interested, I have a USDM resonator type test pipe that I'm no longer using.
Any reason you're staying with a stock cat? Ed
Old Aug 4, 2002 | 12:36 PM
hooptie157's Avatar
Default Re: ADVICE: Can anyone tell me of some of the problems I might have... (Zygspeed)
hey wussup, I own the mugen twin loop exhaust. Other then the bolt your definalty need those tension springs mounted on the hinges. The back pressure caused by the exhaust is crazy, so your need these to avoid crazy creeks and noises, other than that get a high flow cat and enjoy the sounds of mugen
Old Aug 4, 2002 | 03:03 PM
Turtle's Avatar
Zyg - No reason at all . IM me and let me know how much you want for it. Thanks d00d!
Old Aug 4, 2002 | 06:43 PM
ZygSpeed's Avatar
I'll bring it on my next trip back. Ed
Old Aug 4, 2002 | 08:25 PM
K1R's Avatar
K1R
Get some harder (solid) bushing.
Old Aug 4, 2002 | 08:30 PM
CPR's Avatar
CPR
Default Re: ADVICE: Can anyone tell me of some of the problems I might have... (hooptie157)
What are you referring to in terms of "tension springs mounted on the hinges"
Old Aug 4, 2002 | 09:17 PM
yellow blur's Avatar
Don't drop the b-pipe on your front tooth..
yb-b0t: teeth chip
Old Aug 4, 2002 | 09:18 PM
B2FiNiTY's Avatar
Default Re: ADVICE: Can anyone tell me of some of the problems I might have... (yellow blur)
ouch
Old Aug 4, 2002 | 09:35 PM
SoCal ITR's Avatar
Old Aug 6, 2002 | 03:41 PM
EagleR's Avatar
I knw I'll end up being there.......seriously is there EVER a brandon install w/o me?
OJ Glove
Honda Civic (2006 - 2015)
10
Jun 1, 2007 06:17 AM
98ludin
Aug 8, 2003 02:48 PM
TegLover4life
May 4, 2003 09:08 AM
CzanSOHC
Audio / Security / Video
Sep 6, 2002 07:46 PM
