Blox 76mm and skunk2 manifold
Old Dec 21, 2008 | 05:14 PM
j-bird20's Avatar
Default Blox 76mm and skunk2 manifold
Alittle backround. Its a 89 si with a d16y8 motor...stock si throttle cable... i got my manifold ported to accept the 76mm tb. Installation was okay except when it came to the throttle cable. The only way i can get the throttle to be 100% open is to have it cracked open a decent way when closed. I tried all different ways adjusting the cable and it seems thats the only way i can make it work. My question is...can i just clean up my tune alittle and turn down the % on my IACV to keep the idle down since the tb is gonna be open alittle
Old Dec 22, 2008 | 06:59 AM
alterdcreations's Avatar
Default Re: Blox 76mm and skunk2 manifold
bend the throttle pedal up. then it will pull the cable to wot
Old Dec 22, 2008 | 12:00 PM
j-bird20's Avatar
How am i gonna bend the pedal?? i was thinking if the pedal has an adjustment under the dash but i dont think it does
Old Dec 23, 2008 | 03:07 AM
just grab the pedal and pull it up. either i am strong or the pedal is very easy to bend. you should only need to bend it up a half inch. give it a try. grab the bottom of the pedal and pull away from the floor.
Old Dec 23, 2008 | 11:58 AM
Joeski99Si's Avatar
when you say 100% how do you know that? by eye sight or is your car hooked up to a computer ?
Team PHATBOYZ
Jun 17, 2010 01:56 PM
Muckman
Oct 7, 2007 03:25 PM
theresyourproblem
Oct 4, 2007 09:28 AM
1baddturbosi
14
Aug 10, 2007 06:37 PM
blunty
Apr 22, 2002 07:51 AM
