Car and harness is OBD2, engine is OBD1 will ecu work with engine?
Old Dec 21, 2008 | 04:34 PM
halocore's Avatar
Post Car and harness is OBD2, engine is OBD1 will ecu work with engine?
Ok so my civic and the engine harness i'm using is OBD2, I'm running a obd1 gsr engine and ecu right now. However, i have a faulty ecu, and the only p72 ecu i could fine in my area is an OBD2 one. Do you guys think i'll run into any problems if i get the OBD2 ecu?
By the way the car is a 98 so its already wired with the secondary O2 sensor.
Old Dec 21, 2008 | 05:58 PM
98civdx's Avatar
Master Detailer
Default Re: Car and harness is OBD2, engine is OBD1 will ecu work with engine?
just get a jumper harness.
fabworxs
Jan 21, 2011 06:48 AM
jdmshawn95
Jan 14, 2011 11:12 AM
TeamSTEALTH GSR
Aug 10, 2003 02:58 AM
