High Idle!?!?!
Old Dec 21, 2008 | 03:10 PM
juniestyle's Avatar
Default High Idle!?!?!
i just put a new headgasket and started the motor...it idles @ 4000 rpm...no check engine light and i checked the throttle cable...i also tried retarding and advancing the timing but no effect...what could be the problem???
Old Dec 21, 2008 | 07:28 PM
mouab18c1's Avatar
Default Re: High Idle!?!?!
check for any coolant leaks...vaccum leaks...
Old Dec 21, 2008 | 07:36 PM
juniestyle's Avatar
i have a boost gauge w/ vaccuum...what is it suppose to be???
whoisjotothesh's Avatar
Can anyone tell me were i can get a tranny for a 2000 b18c1 gsr ?
Old Dec 21, 2008 | 10:10 PM
averyvm's Avatar
Check and see if you have a vacuum leak by takeing of the intake and covering the throttle body with you hand. the motor should choke and shut of if it doesnt then you most likely have vacuum leak somewhere
Old Dec 22, 2008 | 09:05 AM
mouab18c1's Avatar
i think you're lost...check in the marketplace son....or look locally on craigslist...
Old Dec 22, 2008 | 07:32 PM
juniestyle's Avatar
ok will try and let yall know...thanx for the input yall!!!
Excusetoboost
Sep 1, 2011 07:40 PM
allshownogo
Mar 25, 2008 12:15 PM
ge_ej1
Jan 29, 2008 05:09 PM
PhilMac
Jan 14, 2008 11:35 AM
Matt00
Nov 3, 2005 06:01 AM
