going OBD1
what all do i need to do/ what do i need to convert my ek b16 hatch from OBD2A to OBD1?
so far i know i need the harness converter as well as the ecu...
do i need to disconnect the second O2 sensor as well?
help me out mayn
help me out mayn
just wondering if anyone else thought about this. he says wants to convert his b16 hatch from obd2a to obd1. honda never made a obd2a b16. from my recollection. all obd2 b16 ecus were obd2b
'96 - '97 Del Sol Vtec, JDM B16A (all of the JDM versions are OBD2A except for the B16B.
its a 98 civic cx OBD2. i said OBD2A cause i have a b16a2 swap with the same harness fron the D16. but i need a jumper harness, obd1 dizzy, and p72 or p28 ecu??
the motor is a obd2 as well as the car
You do no need, nor would you even want an OBD1 distributor. All you need is an OBD2A to OBD1 conversion harness and either a chipped P28 or an OBD1 P30.
exactly.
yes, either put a plug in the hole or just leave the O2 sensor in to plug the hole
They don't
They don't
Jason703Racing
Mar 28, 2006 07:13 PM
