Clunking Noise
Old Dec 21, 2008 | 07:10 AM
m47131's Avatar
Default Clunking Noise
Hello,
I have a 1999 Honda Accord, automatic 2.3 lieter and I'm hearing a loud clunking noise coming from the front of the car when I am driving, especially when I accelerate or de-accelerate. It sounds like something is about to break. Also the steering wheel is vibrating when I drive.
For a couple of months the clunking noise was only when I went over bumps and wasn't real loud, now the since yesterday it's doing it all the time. Any ideas on what this could be? I just had new break pads and rotars put on the front about a month ago.
Old Dec 21, 2008 | 10:03 AM
P_Adams's Avatar
Default Re: Clunking Noise
Originally Posted by m47131
Hello,
Is it a hard metal/metal clunk, or a metal/rubber thud?
Is it rythmic? Does it do it turning? Only over bumps? More going forward that reversed?
If I was sitting in the car, I could probably put my hands right on the problem... but this is a tough venue for diagnosing noises
P
Old Dec 21, 2008 | 10:15 AM
m47131's Avatar
I would have to say more of a metal/rubber thud. It does not thud when I am turning, only when going over bumps and straight driving. Does not thud in reverese.
Thanks.
Old Dec 21, 2008 | 12:15 PM
P_Adams's Avatar
Thanks.
I'm thinking one of several things:
1) Upper Strut Mounts (sounds upper (Dash cover area))
2) Inner sway bar mounts (sounds lower (by your feet))
3) Motor Mount (sounds lower (a) by Drivers feet), b) by Passengers' feet), c) below console).
P
Old Dec 21, 2008 | 12:41 PM
burningrex's Avatar
i'd say look at your motor mounts...
most likely them... if not check what P Adams said
Old Dec 21, 2008 | 02:17 PM
tpot90's Avatar
P
Possible. But he said he just had new pads & rotors put on recently. When I had my balljoints done, they had to take my rotors and everthing off. Soon after this, my car started clunking bad when accelarating from a dead stop and coming to a stop. I figured they forgot to put something back correctly.
I took my front wheels off and tightened the 2 front caliper pins/bolts that are found on the inside of the brake setup (the two bolts that hold the caliper on). I'll try finding a diagram for you if you dont understand what im talking abut. After tightening these bolts, the clunking went away.
Old Dec 21, 2008 | 02:34 PM
m47131's Avatar
I just got done driving again. The clunking and steering wheel vibration gets gets worse as I am slowing down and not braking. When I am braking there is no clunking. When I accelerate it still clunks but not as bad as when I take my foot off the gas.
Old Dec 21, 2008 | 02:43 PM
tpot90's Avatar
Lube all your bushings. Tighten everything you can.
sportlead
Oct 8, 2008 05:07 AM
wowowee
Oct 20, 2005 07:39 AM
Supra
May 11, 2004 01:48 AM
