B swap into a 97civic ex
i was looking for mounts and came across this on ebay
http://cgi.ebay.com/ebaymotors/96-00...Q5fAccessories
was wondering if it was worth buying or is this crap thatll break on me
it fits b and d series purely becuase they are only the d/s and p/s top mounts and the central rear engine/tranny rubber mount, if you swapping a b-series in, you still need the lower d/s and p/s from your USDM 99-00 SI (or any UKDM/JDM 96-00 EK4/JDM 96-00 EK9) along with the central rear mount "bracket" from the same civic as well
al9955
al9955
al9955
al9955
Everything you need should be right here:
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/engine-swap-info-faqs-how-ck-engine-lights-878010/
i called autozone and they told me they have the lower d/s mount and their computers dont show anything for a lower p/s mount and also the comp didnt show anything for a rear mount bracket
it will keep the engine from torquing and it is a safety isssue as well.
it keeps the engine from going into the passenger compartment in the event of an accident.
i was lookin at these
http://cgi.ebay.com/ebaymotors/ws/eB...m=200269257839
if i buy this will i still need more mounts?
you would just need to re-use your torque mounts
now i got a question about the ecu, this car is going to be my daily driver so its auto, im putting in a b20b and a b16 trans what ecu should i be using?
-there are no automatic mounts to swap a B-series in an EK, so you'll have to fab something up on your own
-You have to cut the frame rail to get the transmission case to even fit.
-There isn't a proper ECU out there to allow this to happen, and there isn't anything you can really do about it either. Some may suggest using an OBD1 JDM SiR-G automatic tranny, TCM and ECU. However the JDM automatic P72 uses an OBD2 style eprom, so you can't chip it to run a B20, leaving you 100% screwed unless you want to run an LS tranny, TCM and ECU, at which point its gonna be geared long, still require a ton of fabrication. The only thing I can think of that may work is a JDM automatic OBD1 B16A ECU which i'm told doesn't use a TCM. Oh, and that integra TCM is about 40 wires to run as well. Its far, far easier to simply swap a manual in there which will actually work right.
Just so no one thinks i'm completely nuts about the Automatic P72 using an OBD2 style eprom, observe.
Edit, I dug this up, observe --> https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/honda-gsr-swap-getting-pita-2364737/
I know he was trying to do a GS-R swap, but everything still applies to you.
ok so ive decided to go ahead and cut my losses and convert my car to manual ive got the b20b now i just need to find a b16 trans, once i get that what ecu should i be running?
and i was looking for rear bracket, do i need this to mount the engine?
http://cgi.ebay.com/ws/eBayISAPI.dll...m=250346648249
