Rust in Cylinders...
Old Dec 20, 2008 | 02:18 PM
DEPintheCurve's Avatar
Icon2 Rust in Cylinders...
Hey Guys,
I picked up a block for a B16A2 today for $30, kind of planned on having to get some machine work done to it... There is rust in the piston cylinders... Can machine work take care of this adequately? I was able to clean a lot of it out of the cylinders by putting oil on a rag and cleaning off the walls of the cylinders in that fashion. However, there is still a small amount left in two, and good amount in the other two. I tried to take pictures but they did not turn out very good... Let me know what you guys think. Thanks.
Brian
Old Dec 20, 2008 | 02:21 PM
Andrew-L's Avatar
doesnt look bad from the pics, should hone out
Old Dec 20, 2008 | 02:35 PM
slow88si's Avatar
x2
Old Dec 20, 2008 | 02:46 PM
boostfreak2285's Avatar
hone.
Old Dec 20, 2008 | 03:43 PM
Eighty-Nyne's Avatar
Get at it
Old Dec 20, 2008 | 04:13 PM
sgallagher's Avatar
Just slight surface rust. If you plan on machine work you'll be just fine.
A hone like pictured above or a ball hone may also do the trick.
Old Dec 20, 2008 | 04:49 PM
traxxasx's Avatar
You can use some steel wool to get it out also.
Old Dec 21, 2008 | 10:01 AM
2slow4stock's Avatar
Default Re: Rust in Cylinders...
If your going to work on the block. It doesn't matter if there is rust on the cylinder walls, because you are going to get it honed or bored over for your build.
Old Dec 21, 2008 | 11:12 AM
at least we hope lol
Old Dec 21, 2008 | 12:40 PM
It will because honing takes away the surface. If worse comes to worse bore it over, to the next size problem solved.
Old Dec 21, 2008 | 01:13 PM
xsirenax's Avatar
if you get that rust taken care of dont forget to oil up the block so it doesnt rust again.
Old Dec 21, 2008 | 03:24 PM
When he gets the block done, I hope he puts it back together. Rather than just sitting there, after the fresh rehone or bore.
Old Dec 22, 2008 | 07:30 AM
Yes I plan on having it bored, thinking 81.5... And I made sure to oil it this time too. I think the guy who sold it to me must have just let it sit on the garage floor. But yes, will do with the oil. How much will a bore job cost?
Old Dec 22, 2008 | 09:05 AM
Andrew-L's Avatar
depends on where u get it done, try to find a place with a sunnen ck-10(i think thats what its called)
Old Dec 23, 2008 | 12:04 PM
slow88si's Avatar
My sb 350 was $100 but it also depends on where you get it done.
More precise more money
EKcpe00
Northwest
18
Jan 13, 2013 08:40 PM
GReddy SI
25
Jun 5, 2012 05:25 AM
DulinDragons
Jul 3, 2009 09:00 AM
moto1320
Jul 13, 2005 03:43 AM
HX_Guy
Nov 10, 2001 04:52 AM
