brake master cylinder
Old Dec 20, 2008 | 01:40 PM
speed_demon018's Avatar
Default brake master cylinder
will the ls integra brake MC fit on my 94 civic with abs.. they have the same bore which is 15/16
Old Dec 20, 2008 | 02:19 PM
burningrex's Avatar
no use on from a 91 prelude si
Old Dec 20, 2008 | 02:24 PM
how would that one fit?
Old Dec 20, 2008 | 04:30 PM
Mashimaro's Avatar
it will if you get the matching brake booster with it.
Old Dec 20, 2008 | 05:43 PM
to have a car with abs means expensive brake parts
Old Dec 20, 2008 | 07:09 PM
Mashimaro's Avatar
just an FYI, all Integra's (DA and DC) use a 1" MC if it has ABS. and the 1" MC from a DA will not work with the civic due to the size of the flare-nut closest to the firewall (DA is 12mm, EG is 10mm).
save up your money and do it right...save you a headache down the road
Old Dec 20, 2008 | 07:11 PM
burningrex's Avatar
the integra one the bolts are turned the other way...
the 91 prelude si one has the same bolt pattern as the civic and it's 15/16...
not too many people know... that way you don't have to change the booster...
i ran it before i changed mine to a type r brake booster and 1'' master cylinder...
Old Dec 20, 2008 | 07:15 PM
Mashimaro's Avatar
except for the Integra RS model (DA or DC). the lines are identical in mounting to the EG.
the JDM ITR 1" is the way to go if you don't mind bending the line slightly...both holes are also 10mm flare nuts like the EG.
Good info on the 91 prelude si MC! didn't know about that one since everyone talks about the '91 EX 4-door one!
Corksil
17
Dec 15, 2020 05:44 PM
StreetRacin101
30
Apr 9, 2009 04:38 PM
fongph
Jun 28, 2006 09:16 PM
ISELLRIGHTHANDDRIV
10
Aug 9, 2003 03:38 PM
91 Civic B16
Dec 28, 2002 01:14 PM
