Spark issues
Old Dec 19, 2008 | 09:55 PM
teal91's Avatar
Default Spark issues
i posted an erlyer post about a problem i was haveing with my Ef i my car wouldt start an i nawwored it down to some thing to do with distuber
seen some one use this term wats it mean (plugs and wires were soaked)
OK so i replaced alll my grounds an took my cap an rotor alll the way apart an used some dioeltric spary to clean then it sat in front of a heater all night i put it all back togeather this morning an nothing stilll wont start the plugs that are in there are pretty bad looking could it no start because of fouled plugs..
an im not here to get flamed on my typeing skills as i have seen many do this is fourm for help!!! im 19 an a highschool dropout im upseased with cars an car audio alll i do it work on my car an install car audio
Old Dec 19, 2008 | 10:03 PM
acmoc's Avatar
your plugs are bad, might be that you placed the wires in the wrong firing order.
tell us what engine you have so some can post the diagram, I don't know it by heart
Old Dec 19, 2008 | 10:05 PM
SOHC_4dr's Avatar
a new cap and rotor are cheap enough you should just replace them. how do you know your not getting spark? i need more info on what exactly you have done to help your diagnosis. what engine do you have?
Old Dec 19, 2008 | 10:09 PM
teal91's Avatar
d15b2 an i dint unplug any of the wires... but it might help
Old Dec 19, 2008 | 10:11 PM
teal91's Avatar
i knoe im not geting spark it willl turn over an over an it dont sputtter or any thing just turns over an over an over an we have watched the end of alll the plugs in complet darkness an no spark i have replaces alll wires from the battery to the starter alll grounds illl take some pics an post them
Old Dec 19, 2008 | 10:12 PM
SOHC_4dr's Avatar
so how did you come to the conclusion you have no spark? does your motor crank but not start? missfire? any CEL?
Old Dec 19, 2008 | 10:15 PM
teal91's Avatar
yes it cranks put wont start no misfire nothing just cranks
Old Dec 19, 2008 | 10:17 PM
SOHC_4dr's Avatar
ok. when you turn the key on but not try to crank the engine, do you hear the fuel pump prime?
Old Dec 19, 2008 | 10:19 PM
teal91's Avatar
no the car has been siting since i wreaked it a month ago an it use to have an issue that after driveing the car a long time it would have to sit for like ten mins befor it would start any one have aim that could make things easy
Old Dec 19, 2008 | 10:23 PM
SOHC_4dr's Avatar
no spark and fuel? thats quite an issue lol ok so what kind of damage was done? there are so many possible causes i dont think this can be solved online. you may have to end up taking to a shop
Old Dec 19, 2008 | 10:28 PM
teal91's Avatar
it started an every thing for like the first week i had it home an nothing happen that could cause it not to start i punched at guard rail it went in on the passenger side headlight bent the front fram rail goes to the body shop in jan..
an i have never been able to hear it prime when i had my mustang i could
Old Dec 19, 2008 | 10:37 PM
SOHC_4dr's Avatar
well theres a long list of things to look at and ill tell you some common issues to look at first.
1. check your fuses. all just to be safe
2. put a flat head screw driver on the metal casing of the fuel injector, then have someone crank the engine and see if you can hear the injector click. if not then check to see if its getting power and ground.
3. check to see if your FPR is leaking. take off the vaccume hose and if fuels comes out the hose, replace the FPR.
4. a tune up could help you as well.
try those and let us know what you find
FYI: next time in your first post, you should always tell us the motor you have, work done if any, issues and what you have done to find out a possible issue. GL!
Old Dec 19, 2008 | 11:30 PM
teal91's Avatar
my grounds are alll brand new an i get power to everything im just gonnna go to the junk yard an ****** up a whole new distubter with the cap an roter ce if that works cause it started last week i think or the week be for
Old Dec 19, 2008 | 11:46 PM
01-0041's Avatar
So if you're trying to spell "but" how do you get a "p" instead of a "b"? The two keys aren’t even in the same quadrant!
teamTakeo
Aug 20, 2023 07:58 PM
micah13x
11
Apr 14, 2011 03:09 PM
BrothaSit
Sep 26, 2004 07:15 PM
wanna b R
Aug 25, 2004 01:02 PM
96whitels
Aug 19, 2001 02:06 AM
