EF Dash?!
yea.. taking out is a cakewalk, but installing it back was a pain. first time i had 3 extra screws.. after about 10 times of taking it out, i only have 3 12mm bolts holding mine in. u will know what im talking about when u get it out.
so its not to hard to do then? because i was thinking about make a custom dash. and i need to check my heater out because it doesnt work of course being an EF lol.
to get the steering wheel off do you just pop the center cover off and the bolts and what not are right there?
thanks, Casey
thanks, Casey
If you are thinking about modifying the entire dash, you might wanna look into your state laws for repercussion related to tampering with the VIN number. I know it doesn't fly in California...
I know that there's one on each side of the dash ( you have to pop the plastic side vents off) one in the center of the dash right under windsheild, i'm pretty sure there's one behind the glove box, you have to unbolt the center consil bracket from the floor, there's a ground that's going to be attached to the frame of the car that you'll have to disconnect as well, other than that i think that's it.
Yep, you can get yourself in some deep crap if you modify the dash or take off the vin from where it should be.
sweet. awesome. thanks a lot guys. it built a lot of confidence so now im going to do it soon and mess around with some stuff. im going to just keep the dash the way it is. i would like to paint it all black as well. is it possible to paint it since its that odd material? not sure what its called.
o and as my heater. it works. but none of the fan controls work??? whats the deal?
thanks, Casey
thanks, Casey
Check this DIY for painting, and definitely check the FAQ section, info is definitely there.
http://www.clubcivic.com/board/showthread.php?t=84194
People are raving about this particular paint by SEM called landau black, as well as other SEM prepping products. Look it up.
You might get harassed; they can be dicks about it. They might suspect that your car is stolen and you just slapped on a different VIN tag...hopefully you don't have a RHD conversion and your firewall VIN is still intact for comparison purposes.
i might need a new dash...i have not taken a good look at it, but looks like the plastic part that holds the G/B is broken...i wonder if i need a new dash just for that...at least this thread answers my question " is it hard to take out ".
