Wiring question?Already searched
I just got done going through about 15 pages of threads about wiring a b18a1 into a hatch thats already had the multipoint conversion.Some of them said its plug and play and some said there is more wiring to be done,but in all the links that were posted its only the dpfi to mpfi and no mention of the other wiring that needs to be done.So I'm just trying to get a definate answer.Like I said I have already searched and hated to ask this question but I am not clear on what all is involved.
Thanks,Bobby
Thanks,Bobby
if your car is already converted then it should be pretty much plug and play. an ls motor is basically a d series with an extra cam. all other sensors and everything else match up fine.
And I am staying OBDO.
if you are already MPFI, then you are fine. All you will have to do is swap on a plug for the alternator as the b series alternator plug is different. Myself, I used the D series alternator with a different pulley so that everything stayed plug and play.
Wrong! All OBD0 plugs are the same. OBD1 alternator plugs are different. I used my oem harness which was a d series and plugged right into a b16 alternator. Trust me!
FBPninetynineEM1
Mar 18, 2003 01:24 AM
