Ignition lock?
So my car died on the highway, the rpms dropped to zero, but I was not coasting.
Essentially, somehow, my car still runs, but the rpm needle drops and battery light flashes. I can start it, it turns over, but dies as soon as I let go of the key.
If I'm really REALLY nice to the key, it'll stay on, switch on the radio/interior fan, etc.
Is it the ignition lock, just worn out?
P
You should be able to get the part anywhere but the best place is a dealer part, check E Bay too, if the car runs all the time while holding the key in the start position III then the electrical portion is bad, also when you turn the key to ON position II and if the idiot lights do not come on then the electrical portion of the ignition switch is bad also. You do not need to key or lock portion, only the part with the electrical wires attached to it.
Thats correct, just be sure to order the exact part for your exact model and trim, you may not be able to return an electrical part if you get the wrong one and its proved that you ordered the wrong one.
35130-SM4-305
Refer:
http://www.hondapartsdeals.com/hpa_parts_list.php?vin=&Label%5BProductID%5D=ACCOR D&Label%5BYearID%5D=1991&Label%5BDoorID%5D=4&Label %5BGradeID%5D=LX&Label%5BAreaID%5D=KA&Label%5BTran smissionID%5D=4AT&Label%5BSectionID%5D=ELECTRICAL+ %2F+EXHAUST+%2F+HEATER+%2F+FUEL&Label%5BIllustrati onGroupID%5D=COMBINATION+SWITCH&ProductID=5&YearID =30&DoorID=4&GradeID=5&AreaID=2&TransmissionID=5&S ectionID=5&IllustrationGroupID=6796
Number #10
P
So I took off the cover and found out that I don't even need to remove my steering wheel. I took apart the mechanism that actually does the switching, and cleaned the connections and still couldn't make it work. I checked the fusebox and then headed to a parts store with a replacement. I plugged it up and it works great!
Thank you so much! You saved me a lot of time, money, and worry and even made me look pretty good in front of my wife!
Thank you!
Thank you!
SCMFOX
Apr 2, 2018 06:57 AM
Troubleshot
Aug 27, 2015 10:55 AM
