SRS Light Issues
I tried resetting my SRS light but it does not reset. Does this mean that I have something that needs to be fixed?
Symptoms are: horns do not work, and cruise control doesn't work. I've been told that I need a new clock spring.
Also do you have to plug the yellow sensor back into the "dummy" socket?
You sure all the yellow connectors under the dash are plugged in? Look especially for the one just up and inboard of the fuse box, close to the steering column, with a green/red wire, a green/black wire, and a couple of other wires coming out of it.
With the CC and horn not working and the SRS light on, then it is going to be either the above connector; one of the clockspring connectors; or indeed a new clockspring (a.k.a. "cable reel assembly" at Honda parts stores).
Junkyards tend to have plenty of the cable reel assemblies. They do not fail often, so I would suspect a loose plug first.
WaryDriver
Feb 20, 2016 08:26 PM
klomast3r
Oct 5, 2005 09:48 PM
