Where to buy oil pan bung
Hi-
Where can I buy a bung to weld to the oil pan for my DRAG turbo kit? What size, -10? Thanks, any input would be appreciated...pics are welcome as well, I have heard many different things from multiple people and am interested in finding out the truth...thanks again
no, you'll have either a 3/8" or 1/2" to a -10 Male from the turbo drain flange, then the -10 hose ends and lines.
this fitting will connect the -10 hose end to the oil pan..it has nothing to do with the fitting off of the turbo
-10 is equivalent to a 5/8"
the turbo drain flange comes in 2 sizes 1/2" or 3/8"
two different things
The EARL'S fittings oil return set up is a better set up then the drag one, you will need the following parts (some engine setups may require different angle swivel adapters)...
1XEarls PN#804610 -10AN 45 Degree swivel seal Adapter
2XEarls PN#981610 -10AN to 1/2" NPT Adapter
1XEarls PN#809110 -10AN 90 Degree swivel seal Adapter
Approximatly 1 foot of Earls -10AN Perform-o-flex hose.
1X -10AN Bung welded to oil pan
do you have part numbers for summit or anyone else? I would really appreciate it, Im in the final stages of completing the turbo and would love any input....you guys always seem to help me out when I have problems...
ps i need the lines for the feed and return...
OH also, does the DRAG downpipe come with a bung for the 02 sensor? If not...what thread pitch and size is it? Thanks again
b18eg6
b18eg6
If you are a flaker, then i listed the parts above already, go to summit and use the part #'s in the manufacter search under earls. the drag dp already has the 02 sensor bung(s). Id recommend buying them from 93LS though...
[Modified by GudeH23a, 6:32 PM 8/4/2002]
reignofchaos
Jul 31, 2003 07:48 PM
orange.honda
May 6, 2003 04:14 AM
